Question about Hotpoint NVL333GY Gas Dryer
My wife brought a Hotpoint gas dryer into our marriage, which we didn't use for the last 4 years because we were renting a house. Now we have our own home, and the dryer is hooked up for gas and venting, but I can't figure out how to light the pilot (I assume there is one). The gas line is open (tap handle parallel with pipe) and the power is on. I have removed the plate at rear lower right, but I can't see a pilot in the recessed slot, or hear any gas going through. How does this thing work?
  • 6,784 Answers
Hi. I am assuming that you have selected the correct model number when posting your question. At the top of this page, it says that the your unit in question is a Hotpoint NVL333GY. If this is not your model, please post the entire correct model number, asap. This is a very important issue that can greatly affect the accuracy off the solution.
With that said; This particular model of Hotpoint dryers are not equipped with a "traditional" pilot light configuration. This unit is equipped with a booster coil assembly and glow ignitor. The glow ignitor is basically your lighting apparatus and the coils open and close the gas valve, with the help from a few monitoring thermostats and the main control board or timer mechanism. If you have power going to the unit and gas is on, you should be able to start the cycle by selecting a drying cycle with the timer dial and pushing the start button. If the dryer dose not respond, or if the drum turns without any heat, this will be the result of a failing burner assembly(coil damage or ignitor failure) or the timer and monitoring thermostats/fuses maybe suspect.
Click here to view a exploded diagram of the burner assembly in this model.
The flame sensor is labeled number 1379
The ignitor is labeled 1374
The coil assembly will be labeled 1372 and 1371(Boost and secondary coil are mounted together)
The burner is labeled number 1377
The actual valve is labeled number 1370
All the parts above make up your burner assembly, in this particular model.
Here is a basic summary on how these dryers work.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Burner assembly inspection:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Posted on Aug 06, 2010
Hello, I bought an Hotpoint washing/dryer Wdl 540 acquarius+ last year and since then all my house stink of ****. Especcially when the dryer is on and all my clothes and my house stink terribly. What can...
Because the units are combined the dryer has a built in a condenser dryer which should have a water retaining tank and if not emptied regular it can stink like ****. You need to empty the tank. Your model should pump the moisure out but has a reserve tank.
Jul 26, 2011 | Hotpoint Aquarius WD640 Front Load...
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Hi, My wife noticed a smell of propane about a year ago. I bubble-tested all the gas connections inside our house, we also have a propane stove, but I couldn't find any leak. We got a $523 gas bill...
sounds like your gas valve is leaking through one or more of the gaskets. It definitely would be worth your while to fix the dryer considering the amount of propane you're losing. That's a big gas bill! Unless you have already tried it this way I,you could use a spray bottle with some real soapy solution you will probably find it.
Apr 12, 2011 | Estate TGDS840JQ Gas Dryer
Moved to new house and it's not a gas hook up just electric
You will have to replace the dryer with a electric one or have your local gas company install tank and run lines for you unless there's natural gas line where you live which you will need the city come and run a line or a qualified gas technician come do it but this will be costly. I would recommend buying a good quality used one or a new one it would be cheaper. Also since the gas prices have been sky high on propane and NG allot of people have switched to electric over the last two years and most appliance company's even mine wont trade or give anything for it just a fyi but good luck and hope this helps.
Jan 10, 2011 | Hotpoint NVL333GY Gas Dryer
No heat
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 02, 2009 | Kenmore Dryers
How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Sep 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Trying to establish approximate age of old Hotpoint Refrigerator
http://www.waptac.org/sp.asp?mc=techaids_refrigerator_energyuse
Looks like between 82-84
Jun 25, 2009 | Refrigerators
Dryer runs, no Heat
the ignitor is glowing??? and still no ignition?? if thats the case the thermostats are good, i would focus on the coils located on top of the vavle 279834, about 20 bucks. obvioulsy first check you do inded have gas coming into the unit
Apr 08, 2008 | Whirlpool LGV4634JQ Gas Dryer
Hotpoint NVL333GY Gas Dryer Logo
29 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
