Question about Sony STR-DH100 Receiver
How can i connect my turntable to the sony str dh100 as i can see no phono port like my old amp the turntable is an audiotronic (old but very good)
petraman7
  • 1175 Answers
SOURCE: Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Posted on Dec 30, 2008
bob_computer
  • 3153 Answers
SOURCE: CAN I CONNECT A TURNTABLE TO THIS RECEIVER? STR DE485
The terminals are located at the back and yes you can connect a turntable
There are none for PHONO but you could use the TAPE
(not the MD) inputs (you might need a preamp but worth checking without first)
Depending on your turntable you might not need a preamp as some come with built in.
If this was useful information please click
Posted on Aug 13, 2009
  • 30 Answers
SOURCE: Can I hook up a photo turntable to a sony str-de435 receiver?
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Posted on Oct 19, 2009
  • 4234 Answers
SOURCE: can i use a turntable with the sony str dh500
This particular unit only has 2 line level inputs for audio devices. You can use 1 for the CD player and the other for the Turntable. Please note that you will need a phono pre-amp for the turntable as the inputs on the receiver are line level. The preamp will amplify the phono level to line level.
Dan
Posted on Nov 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: how do i check the
When a fuse blows its permanent.
You may have a control out of position or tt could be in self protection.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.--
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 19, 2011
Do you need a pre-amp to connect this turntable to a receiver that has no Phono input jack?
Yes, a TurnTable can be connected to any of the Analog Audio Input ports on the Sony STRDH130 Receiver. However, the turntable signal will need amplification from an external pre-amplifier (or an inline amplifier) as this Receiver does not have a PHONO input.
Feb 16, 2018 | Sony Audio Players & Recorders
Can I connect a tape deck *and* a turntable to the Sony STR-DE595?
If your turn table has a magnetic cartridge it will not work,Becuase the ner recievers are not equip with a phono preamp, They are equip to only use a crystal or ceramic cartridge in the turn table.
Sep 29, 2012 | Sony STR-DE595 5-Channel Amplifier
How do I hook up a turntable to this receiver
You should have MD/tape on the back with two phonos. Connect the phonos from turntable to IN slot. You should work
Mar 22, 2012 | Sony STR-DE595 5-Channel Amplifier
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
I have a Sony direct drive PS-X5 turntable. I have to turn the amp up all the way to hear any sound.
If you're not connecting the TT to a PHONO preamp or a receiver with a built-in PHONO connection the signal from it will be too weak to get any meaningful volume PLUS the RIAA equalization curve required for flat phono playback won't be applied so it will sound very 'tinny'.
Google it.
Get electronics that can handle old-school turntables.
Dec 27, 2010 | Sony PS-LX250 Turntable
Why can't I play a turntable through my "Sony str-de595
Turntables have a very low output level. Receivers with a phono input have a op-amp to boost the signal level.
What you can do: Check the turn table it may have a line level switch under the rubber mat, otherwise you can get a phono amp ($20-$40) to boost the signal. and input it to any unused input on the receiver.
Jan 10, 2010 | Sony STR-DE595 Receiver
Can i use a turntable with the sony str dh500 model? I am illiterate when it comes to hooking this stuff up. Planning to purchase this model only if I can hook up my record player as well as my cd player.
Dan
Nov 17, 2009 | Sony STR-DH500 A/V Receiver
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
Oct 19, 2009 | Sony STR-DE435 Receiver
Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
May 06, 2009 | Audio Players & Recorders
SONY TURNTABLE PSLX22
You have to make sure your unit is connected to the PHONO INPUT connection on your receiver. If your receiver does not have a PHONO INPUT connection, then you will need to buy what's called a PHONO PRE-AMP - AVAILABLE HERE.
You connect the turntable to the Phono Pre-Amp, then you connect the Pre-Amp to the LINE IN or AUX IN of your receiver.
- Davis.
DIGITAL ANALOG THERAPY
www.repairnyc.com
Jul 05, 2008 | Sony PS-LX250H Turntable
Sony STR-DH100 Receiver Logo
625 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
