Question about Mustek MP72 Portable DVD Player
Ni-MH Battery Pack Model No PL-NiMHHP: Does not charge- not been used- tried to charge but even after 24 hours does not get charged
4 Suggested Answers
SOURCE: battery not holding charge
Probably the battery is dead. You may need to purchase a new one.
Posted on Dec 01, 2007
I had the exact problem as the other two above but resolved the situation as follows: I connected the battery to the charger and switched the power on. The charge light on the battery glowed 'red' as it should and some time later, not as long as it should have been, the light changed to 'green' indicating it was fully charged. At this point I removed the charge lead from the battery and then replacedit. The charge light reverted to 'red' again. When it eventually changed to 'green' I repeated the above step and did so for the next 18 hours. I then connected the battery to the player and played a dvd 1hr 55min film. It worked fine. I hope the solution works for yuo!!
Posted on Nov 11, 2008
SOURCE: Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
Posted on Jun 04, 2010
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Aug 10, 2011 | Mattel Fisher-Price Imaginext Big Foot
Tip
Taking Care Of Your Laptop Battery
  1. Normally, a new battery pack comes in a very low charge condition and must be fully charged before use. Refer to the user manual of your portable electronic equipment for charging instructions.
  2. A new Dell Vostro A860 Battery needs to be fully charged and fully discharged or “cycled” as much as five times to condition them into performing at full capacity.
  3. Your equipment may report a fully charge condition in as short as 10 to 15 minutes when the new Dell Vostro 1015 Battery is being charged for the first time. This is a normal phenomenon especially for Nickel Cadmium (Ni-Cad) and Nickel Metal Hydride (Ni-MH) chemistries. When this happens, remove the dell vostro 1015 battery pack and let it cool down for about fifteen minutes then repeat the charging procedure.
  4. “Conditioning” (fully discharging and then fully charging) is necessary so as to maintain the optimum performance of a sony vgp-bps8 battery, and is recommended at least once a month particularly for Ni-Cad and Ni-MH batteries. Failure to do so could result in reduced charge capacity and can significantly shorten the sony vaio vgn-fz battery pack’s useful life. Lithium Ion batteries do not require conditioning.
  5. It is normal for a acer aspire 1410 battery pack to get warm when charging and during use. However, if the acer aspire 1410 battery pack gets excessive hot, there may be a problem with the portable electronic equipment’s charging circuit and should therefore be checked by a qualified technician.
  6. Rechargeable batteries undergo self-discharging when left unused for long periods of time. This is normal particularly in the case of Ni-MH and Li-Ion chemistries. For best results, always store a battery pack fully charged. It should be removed from the equipment and kept in a cool, dry and clean place.
  7. The amount of runtime a hp 510 battery produces depends on the power requirements of components in your electronic equipment. This could be the hard drive setting, screen intensity and back-lighting on notebook computers, the liquid crystal display (LCD) screen and floodlight feature in a video camcorder, or the tri-mode communications network of a cellular phone. Always refer to your equipment’s user manual for power management settings.
on May 31, 2010 | Computers & Internet
Tip
New Laptop Battery Use Tips
Taking Care Of Your New Battery Pack
A new laptop battery pack needs to be fully charged and fully discharged or “cycled” as much as five times to condition them into performing at full capacity.
Your equipment may report a fully charge condition in as short as 10 to 15 minutes when the new battery pack is being charged for the first time. This is a normal phenomenon especially for Nickel Cadmium (Ni-Cad) and Nickel Metal Hydride (Ni-MH) chemistries. When this happens, remove the Dell xps m1530 Battery pack and let it cool down for about fifteen minutes then repeat the charging procedure.
“Conditioning” (fully discharging and then fully charging) is necessary so as to maintain the optimum performance of a battery pack, and is recommended at least once a month particularly for Ni-Cad and Ni-MH batteries. Failure to do so could result in reduced charge capacity and can significantly shorten the battery pack’s useful life. Lithium Ion batteries do not require conditioning.
It is normal for a battery pack to get warm when charging and during use. However, if the dell Inspiron 2650 Battery pack gets excessive hot, there may be a problem with the portable electronic equipment’s charging circuit and should therefore be checked by a qualified technician.
The amount of runtime a dell inspiron 8600 battery produces depends on the power requirements of components in your electronic equipment. This could be the hard drive setting, screen intensity and back-lighting on notebook computers, the liquid crystal display (LCD) screen and floodlight feature in a video camcorder, or the tri-mode communications network of a cellular phone. Always refer to your equipment’s user manual for power management settings.
on Apr 20, 2010 | Computers & Internet
The battery model no.PL-NIMHHP DOES NOT CHARGE.
I need a new battery pack for my DVD player dvdp722 where can I get one please
May 20, 2011 | Mustek MP72 Portable DVD Player
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
What kind of rechargeable battery goes in the Kodak Easyshare Z710?
Z710 can use:
KODAK Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your KODAK Digital Camera and KODAK EASYSHARE Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger.
For more information on your camera plese follow this link:
http://www.kodak.com/global/en/service/products/ekn032171.jhtml?pq-path=9374
Dec 17, 2009 | Kodak EasyShare Z710 Digital Camera
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
This is the second Ni-MH battery I've bought that I've used infrequently over the last year and now it doesn't hold much of a charge after I charge it. Some people say I shouldn't leave it on the charger...
Any battery should start charging for over 8 hours and then it goes down to 4 hours, however no one working on a job wait 4 hours to get the batteries charged so they start cutting time and for that it get less and less charges inside and after a while it refuse to take any charge..Drain your batteries totally, charge them over night, see if that work if not just use them tell you are done with them, and get new equipments not new battery. When buying new equipments and charging them remember never use it until you fully charge it for 8 hours and not even use it for a second before it’s fully charged... Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Drills
Mustek MP72 Portable DVD Player Logo
758 people viewed this question
Top Mustek Televison & Video Experts
Tom Chichester
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
