I need super cheats of cricket 2005?
Getting the opposition out quicklyTry bringing the medium fast or medium bowler on. Then, place the bowling marker just short of the good length spot or even further down towards the bowler. Try inswing ball or outswing but drop the speed to almost nil. Keep the speed to two or three lines (yellow meter). The batsman will play a backfoot defensive shot and eventually get bowled or LBW.
A second way of getting the batsman out quickly is bring the medium fast or fast bowler and try bowling inswing bouncer and place a fileder at deep thirdman for a catch. This trick only works when the batsman is new to the crease or tailenders.
Votes: 1 100% 0%
Easy run outs
Go to "My Cricket" then click "Game Settings". Set "Auto Fielding" to "Manual Fielding". Then, start a match and choose a fast bowler. Change the field by using "Field Editor" and select "Retreat 3:. Bowl out side offstump batsman will defence. Do not get to the ball immediately. Wait for two or three seconds. The batsman will run. Go and pick the ball and press [Space] + S for hitting a direct aim at non-strikers end or [Space] + W for hitting a direct aim at strikers end. Most of the times the batsman will be out. Note: Be patient as the batsmen will not not run sometimes.
Votes: 1 0% 100%
Easy six shots
The more you play, the more you will master the game. It is not easy to start hitting six shots from the start. Even after much practice you will find it difficult to play the all the shots. The best way is to play six shots down on the long on and long off boundary using [Down] + [Shift] + S. Players who have good calibre like Sachin Tendulkar, Virender Sehwag, etc. will be find it difficult to hit six shots. If you try with other players you may end up with a mis-timed shot and give a catch. If bowled onto the stumps, for beginners play it down the legside using S + [Right].
Votes: 0 0% 0%
Easy six shots
Votes: 1 100% 0%
Keeping the scoreboard moving or hitting some runs
Always bring the left handed batsman first and aim for the leg side boundary for six hit shot. He will succeed many times.
In test matches, do not rush for runs or you will get out very quickly. Place your innings and play the ball in the gaps.
Votes: 0 0% 0%
Get batsmen out fast
Bring in a fast bowler (for example, McGrath) and aim a normal delivery behind either the middle or the off stump. Put the bar up to almost full power and let her rip. Most batters will swing and miss or be caught LBW.
When bowling with someone who has a slower ball (for example, McGrath put the pointer as near to the bowler as possible, then put the pointer just to the left of the umpire. Put the power to two yellow bars. Then watch them walking in and out of the Pavillion.
Votes: 0 0% 0%
Easy six
When the ball is pitched just in front of your leg outside offstump or towards middle stump, sweep it through the legside by a powershot. Most of the time the result will be a six.
Votes: 0 0% 0%
How to make the opposition out in 20/20 matches
Normally in 20/20 cricket in this game when you are playing against a strong team like Australia they remain in 15 overs at about 130 for no loss. But to make all the batsmen out quickly after 15 overs choose a pace bowler( For example Irfan Pathan ) and place the ball mark after the middle stump and make tsure the ball speed is full. Then the batsmen will become bowled or caught at long on or Long off.
Note:
1. This will only work on pace bowlers
2. this might only work if the game is et in easy mode
Good Luck
Dec 11, 2008 |
EA Sports Cricket 2005 for Windows
hw much it mite cost me??
