Question about Sony Walkman WM-D6C Personal Cassette Player
I have a Sony Professional Walkman WMD6 I bought when they first came out. I'm looking for the battery case & a pair of Sony stereo condensed mikes. Regular mikes don't work because the bands on the pin input aren't properly spaced to fit the unit. I inadverntly tossed them after Katrina.The walkman is fine & didn't stay at the house when I evacuated for the storm. HELP?
SOURCE: My Walkman won't charge
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Posted on Jan 01, 2009
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
  • 4 Answers
SOURCE: sony walkman TCD-8
Clean the heads or use a tape cleaning tape.
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Posted on Feb 26, 2009
  • 11 Answers
SOURCE: Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Posted on Apr 03, 2009
I'm new to the Car Audio seen.I just bought four 6x9's.Now I need a good Amp to push all four of them.Here's what I have.Sony XS-R6945 4 Way 6x9" 800 watt Full Range Car Stereo Speakers Power...
Look for a 4-channel amp that pushes 50 watts RMS @ 4 ohm.
Make sure the amp is CEA-2006 compliant.
Ignore peak or max watts as these are arbitrary numbers.
More info here - sparky3489.webs.com
Jan 24, 2015 | Car Audio & Video
I bought a Sony MP3 Walkman and Altec Lansing IM510 Speaker System that has a docking station for a 30 pin adapter; is there an adapter made to solve this problem?
Yes!!! Check the voltage size, get a docking station 30 pin adapter, which has the same output and input voltage size. and thats gonna solve it for you ok.
Feb 29, 2012 | Sony Walkman Video NWZA818 MP3 Player
Sony walkman cant be turn on
Make it full charge then try & If it is not give it back where u buy this thing
Jun 02, 2010 | Sony Walkman NWZ-S616F MP3 Player
I bought a used car with a sony explode car stereo and it has a blue tooth feature with no instructions. how do i pair it to my phone?
go to sonys website and there should b a link to stereos and give u instructions how to pair up stuff.....if not go to google and type in "free manuals 4 sony (and put ur stereo model number in)" and u should find instrutions how to do this.
May 07, 2009 | Car Audio & Video
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
How do I put a video that I bought on itunes onto my mp3player?
Walkman Video Converter Convert video espeically high definition video to Sony Walkman/ Sony Ericsson Walkman phone MPEG-4/AVC, MP3, WMA and M4A. Edit video with unique editing features to trim, crop, adjust effect, add watermark, etc.
This Walkman Video Converter can also extract and convert audio from video to Walkman audio formats including MP3, WMA and M4A. This Walkman Converter completely supports Sony Ericsson Walkman phone, Walkman Bean, Walkman Buzz, Walkman Fitness and more.
Jan 30, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Playing sony mp3 walkman through stereo component
use adapters to connect the cables from your mp3 to your stereo. you can buy these adapters on some eletronic shop.
thank you for using fixya
CHARCOIS
Nov 18, 2008 | Sony Walkman NWZ-S616F MP3 Player
My Sony Walkman WM -SR10 is not recording and the cassette tape is not working. Only the radio is player. And I cannot get another one to buy even its not the same. Can you help me
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Nov 09, 2008 | Sony (Personal Audio) Walkman AM/FM Stereo...
Sony Walkman WM-D6C Personal Cassette Player Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
