Question about Kenmore Oasis HE 27082 Top Load Washer
LD error on Kenmore Oasis HE 27082
I bought my Kenmore Oasis HE 27082 in March of 2007. Approximately 4 months after I got the washer I started having an error on the washer that said "LD". The manual and repairman said that "LD" means Long Drain, and that it probably means my drain pipe is clogged or not working. Two different Sears repairmen have come to try and fix my washer, one replaced the control board, and the other replaced the motor. Both times it didn't fix the problem. I've diagnosed this problem pretty specifically and know exactly when it will malfunction. Right before the washer should Start Spinning the clothes, it will just sit there with the motor running for a few minutes. Then the "LD" error will come up. I've checked the drain pipe thoroughly and have concluded that it is working perfectly. It seems that your diagnosis of this person's problem was identical to my problem. The 2nd repairman though my washer was "oversudzing" but I have cut down and use extremely small amounts of HE detergent. I believe the washer is sending a false signal to the board and will not initiate the spin cycle. Is there a way I can manually get the washer to just do the spin cycle? Is there anyway I can fix this problem myself? Your help would be greatly appreciated, thank you in advance for your time.
I had the same problem with F1 and F68. I just bought a $345 new computer for my washer. These machines are defective. Mine was purchased in Nov. of 2006 but not even out of the box until Jan. 2007!!!
Posted on Apr 29, 2008
Oasis HE 27082 Stainless Steel Top Load Washer: how do i soak whites in a kenmore elite oasis?...
There is not a program - you have to do it manually on this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What is the mean of LD code for kenmore oasis he?
See the following Whirlpool Service manual for the Oasis / Cabrio washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Jan 22, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis code ld can you help
HI There
I want to say is Merry X-Mas and a Happy New Year. I have found what you need and hope this get's you in the right direction. Let me know how it went.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best Regards Richard
Dec 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
395 people viewed this question
Sal De
fordexpert
Robert Rankin
