Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Unable to connect unit to my pc - Maxent MX-42HPM20 42 in. Plasma HDTV
  • 755 Answers
Your HD tv should have a blue DB15 connector on the back.
If not you need to get a video card with HDMI or S-video outputs.
Is there another issue? If you have the tv cabled to the computer already you need to switch input on the tv to computer via the remote control.
Posted on Aug 06, 2010
Its saying unable to init.42
What kind of printer are you having issues with? Is it laser, ink jet, or something else entirely. Try a few things first. Open services in the control panel and stop than restart the printer spool service. Than unplug the unit count to ten than power the unit on. Open all trays and make sure the unit is clean. If the unit is networked make sure your PC is connected to the printer. Reinstall or update the printer drivers.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Nov 24, 2014 | Office Equipment & Supplies
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
Connected Airport Extreme wireless router unit to a PC. Airport Utility interface screen shows message: "Airport Utility unable to find Airport wireless devices...." Displays rescan button...
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Apple AirPort Extreme Router
Powers on garmin shows on screen tthen flashes white and does nothing but repeats the same process
try connecting it to the C if you are able to connect update the unit using Garmins WebUpdater software. if yu are unable to connect to your PC you will have to send it in for warranty.
Hope this helps!
Mar 04, 2011 | Garmin Nuvi 465T Car GPS Receiver
My new garmin nuvi 265W constatntly reboots itself for no reason. I am unable to connect it to the PC to run webupdater on it because when I attach it to the USB, the unit just sits and reboots itself, so...
Have your Nuvi fully charged before you do anything with it
With the unit Off
connect the gps to your computer using the USB cord, your computer will detect new hardware USB port
go to www.MyGarmin.com once there it too will detect your model and give you the correct updates and unlock maps
you must register your unit with garmin
Nov 06, 2010 | Garmin nuvi 885T GPS Receiver
I have purchased SONY MP4 MP5 V321.5678 player and unable to connect to the PC for copy pictures which I have taken. The PC dose not recognize the unit when it connect. Pls advice me.
I have purchased one Sony MP4 MP5 model V321.5678. I could not get the users manuel allong with it. From which site I can get the operational mauel. Please help me in this regard. Thank you.
Oct 18, 2010 | Sony Audio Players & Recorders
Im unable to connect my nokia n70 to pc via cable aithough i had nokia pc suit.when im connecting those cable to nokia 6680 its workking.wt should i do plz help me
Nokia PC Suit software varies in unit models. If you had installed pc suit for nokia 6680 then you need also to install the pc suit for your nokia N70 phone. Use the support cd to install the software.
Hope this could help.
Mar 26, 2010 | Nokia N70 Cellular Phone
Hello, my Sony handycam model no is DCR-SR200 HDD. I can record, replay in handycam. but unable to download/copy the files into my PC. unable to read the memory in the CAM hard disc. please help me. how...
when you connect to PC if you can see the disk/camcorder drive in my computer, copy entire folders to your PC it will work.
possible : Check /replace USB cable
:without using sony software copy files from my computer.
:if lcd not working, use the copy button from the camera docking unit
Nov 29, 2009 | Sony Handycam DCR-SR200 Camcorder
Unable to open a DVD9 Format DVD on my system?
Check the DVD unit specs.
DVD 9 (dual layer DVD) is not for any drive only some are allowing to process.
You can try any external DVD drive (Multi standard ) connected via USB.
Dec 28, 2008 | IBM ThinkPad T41 Notebook
Unable to connect vdr-d250 to pc
I think that the following are to be taken care of first:
1.Cam corder to pc cable is properly connected.Some call it as 1384 connection also.
2.Cam corder should also be run on play mode for transmitting a/v signals to pc to decipher.
3.Ur pc also should have been installed with codec for processing the signals .
4.Your pc also should be usb.2.0 capable.
5.The media on the cam should not be protected for free playing along with pc.
If all the above are checked you would have cracked clear right.
good luck.
Feb 05, 2008 | Panasonic VDR-D250 DVD Camcorder
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
61 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
