Question about Fisher and Paykel DEGX2 Dryer
I have a DEGX2. How do I remove the circular mesh filter behind the lint bucket?
  • 347 Answers
Ther is 1 screw to remove below lint bucket after that ring needs to be pushed in slightly and rotated counter clockwise at he same time to dissengage lockig tabs then you can pull out filter and reverse order to reinstall
Posted on Aug 06, 2010
    New Friend:
This is great advice....however you turn it clock wise to disengage...not counter clockwise.
Posted on Jan 29, 2013
I reset the button on my fisher& payment dryer. It worked for a short while and stopped heating again. What next?
check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem.
this was answered by someone else a year or so ago on this site thought i'd pass it on.
Hope this works.
Dec 31, 2017 | Dryers
Model MTW5840TWO water will not drain on the spin cycle
Perhaps none. Have you checked to see if the lint filter is blocked? Usually, the lint filter can be accessed from the front bottom of the machine, often behind a small door. Open the door, open the filter (have a bucket available to catch water) and remove the blocking ball of lint.
Feb 21, 2016 | Whirlpool Washing Machines
My lint collector wont collect any lint
Step 1:
1- look if the fan are blowing
Step 2:
look if there's lint traffic jam (use a vaccum)
Feb 08, 2013 | Fisher and Paykel DEGX2 Dryer
Does the toyota camry 2001 have air conditioning filters?
No, not officially, however there is a metal grill or mesh behind the front vents that will plug up with lint and not allow air to flow through the front vents. If you remove the upper dash board you can get to it. It took me an entire day to get to it and reassemble my car. It is permanently secured in place with adhisve backed foam, but with the dashboard removed i was able remove it. Considering the difficuly in accessing it i decided to throw away the mesh and then i bought some foam a/c gaskit material to put back around where the mesh was before reassembling the car.
Jul 05, 2012 | 2001 Toyota Camry
How do you remove the filter on the back of a VRT Steam Samsung washer?
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. lanijo58_3.jpglanijo58_2.jpglanijo58_1.jpglanijo58_0.jpg Hope this helps you
Jun 02, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
My bosch gas dryer has a E01 code,would like to known what that is.
It could be a venting problem. Check the lint filter and the vent pipe to make sure they are not clogged with lint. I have heard that greased lighting works well for cleaning the fine lint filter. Also check where the pipe vents and make sure it is clear. Sometimes vent caps have the mesh screens left on them. When cap vents are used the small mesh screen should be removed so any lint that blows through can clear the venting system. I hope this helps. Link for cleaner: http://www.greased-lightning.com/
Apr 21, 2011 | Bosch Dryers
Where is the filter located???
Remove the water bucket and you will see the filter behind where the water bucket was located. It's a foam mesh type filter. Using your fingers, reach under the bottom of the filter frame and gently pull to remove it. Wash the filter with warm water and a mild detergent. Rinse and dry well before reinstalling it.
Hope this helped you. Please let me know.
Apr 12, 2011 | LG LHD45EL Dehumidifier
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX2 Dryer Logo
425 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
