A password is followed after a deep - Computers & Internet
    Master:
  • 515 Answers
So you don't have any idea what that password about, right? Then you can try to enter the BIOS by pressing a key or several keys when restarting according to the model of your computer (instruction about which key to press to enter BIOS should be there on the manual) and then you can reset the password. If there is a password for BIOS either, you will have to try to release the CMOS memory where the passwords are remembered. Some computers may not have that option for security sake. To clear CMOS, try the steps on the following links.
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
I would prefer the other two methods on the bottom of this page to clear the CMOS.
http://www.pcguide.com/ts/x/comp/mbsys/cmosClearCMOS-c.html
This one also have right steps and links for more reference.
In case it is not the CMOS, then I guess you may need a virus scanner for that password prompt after a beep.
Posted on Aug 06, 2010
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
When i install deepfreez i dont know the password please help me i wanted to uninstall this but i need a password
Hi there.
If you purchased deep freeze, I suggest to contact your distributor.
If you didn't buy deep freeze, follow the steps found in this website: Uninstall Deep Freeze.
Hope this helps.
Jun 03, 2011 | Computers & Internet
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
For Deep Freeze evaluations (with no License Key entered):
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
How to uninstall deep freeze from my pc
(Please let us know if you find the following has been useful.)
In order to uninstall it, you need to disable Deep Freeze first. To do that, please follow the steps below:
To uninstall:
I hope this solves your issue. Regards.
Aug 19, 2010 | Computers & Internet
How to uninstall deep freeze version 6.53.020.2763 ? i can't find the uninstaller for this program anywhere in my pc. thanks in advance.
source(http://tricks-collections.com/uninstall-deep-freeze-60-without-password/)
Smart Software for Deep Freeze v.6 to disable or uninstall this software in this time there is no. But with little tricks, Deep Freeze 6.0 can be disable or unintal not requiring password. following way to disable or unintal Deep Freeze ver 6 :
  1. Booting Computer From CD use Windows XP Installer
  2. After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  3. then selected R to repair Windows ( Repair Setup)
  4. Hereinafter continue Install windows untill finish.
  5. Now prepare the Deepfreeze v.6 of and double click
  6. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
  7. Done……
Apr 21, 2010 | Computers & Internet
Deep freeze
To have to retain your password you go 'Forgot your password?' utility. And follow the instructions.
Sep 21, 2007 | WinZip 12.0 - Windows for PC
Computers & Internet Logo
15 people viewed this question
Alun Cox
David Payne
David Payne
