Question about Sharp Office Equipment & Supplies
How to reset code F6-99 of Sharp ARM237? - Sharp Office Equipment & Supplies
2 Suggested Answers
saxmansaxman
  • 177 Answers
SOURCE: Sharp ARM237 crooked prints and jams w/double
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Posted on Feb 05, 2011
Previous admin no longer here, no one knows web password for AR-M257. How to reset?
Maybe order the service manual
http://www.servicemanuals.net/ServiceManual/SHARP/ARM237/572062/detail.aspx
Jan 09, 2015 | Sharp Ar-M257
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
Arm237 f5-02 light goes out after 1 second but should stay on -- lamp ok, cable ok, broke after cleaning optics
It is possible that while the optics were getting cleaned the cable connected to the lamp unit got pulled out enough that it looks like it is connected but isn't connected enough, or the lamp was accidently touched by the person cleaning the lamp and now its bad. I would check the cable that connects to the lamo unit and the CCD first.
Sep 28, 2011 | Sharp AR-M237 Copier
ARM237 with black line on copies The machine indicates lifting the SPF What is that?
The SPF is the ADF > the doccument feeder on top of the copier. Do you only get black lines when you use the ADF? When you lift the ADF up and you see the copy board glass > there is a small **** of glass on the side of the big piece of glass..... Clean the small piece of glass with windex and that should take care of your problem... Good Luck
Feb 04, 2011 | Sharp MX-2700N Color Copier
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
I have a sharp arm237 the error code is h2-01.... I cleared the melted peice of injet paper my daughter used from the heat roller. I still have the error but can't figure out how to clear it.
double check to make sure all paper is removed.
On the key pad press P * C * it will bring up another screen enter 14 and press the copy button it will ask you if your sure you want to clear the error select yes and press copy button machine should restart if error code comes back you will need a tech to come out and check the fuser and connections
Aug 22, 2010 | Sharp AR-M237 Digital Copier
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
