Question about Logitech Z-5500 Computer Speakers
How to dismantle the logitech z5500 satellites .im trying to fill up some foam in them so that i dont get distortion in high volumes as the plastic case is making noise when it vibrates.
  • Anonymous Mar 01, 2009
    i have detached the speaker stand and now coant get it back together as the speaker case seems sealed. is there any way to open the case without destroying it???????? cheers
Remove the rubber that holds the cover on the front of the satellites x4 underneath there are screws x4 unscrew and it will come apart with ease.
Posted on Jun 21, 2009
  • 167 Answers
Can you tighten the screws to fix this? i have same speakers and this worked for me. i know of no easy way to open these without damage.good-luck.
Posted on Aug 02, 2008
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
Dec 09, 2012 | Denon AVR-682 Receiver
Only right side volume working wehn volume is low, when volume is high both sides work but distorted
It may mean that the connection for your left side speakers are loose or they are not connected properly. you can also try plugging the speakers to another music source (ipod, stereo, etc.)
If the same problem happens it is most likely a faulty wiring on the left speakers.
PS - if your computer volume software has the balance option make sure it's in the middle and not set to have output on just the left or the right side.
Hope this helps!
May 12, 2011 | Logitech R-10 Computer Speakers
Can someone please tell me how to connect my logitech z5500 to my lg 42ld460-ta LCD television to get the optimal sound value from the surround sound system? Thanks very much!
Your LG TV has an audio out socket at the back . Your Logitech has a cable with a green pin (headphone type) which normally goes into the PC's sound out. The same pin can be connected to the TV's out. Now if your TV has a digital out at the back, get yourself an optic fiber cable ( make sure its long enough to reach the Logitech ) and connect it to the z5500 for the best in sound !!.
Mar 09, 2011 | Audio Players & Recorders
Logitech z5500 speakers no power
certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Mar 29, 2010 | Logitech Z-5500 5.1 Digital Speaker System...
Z5500 speakers , can it be opened
Hi , And happy new year , You speakers can be opened , but the second you open them, you will lose your warranty , if thats ok with you , then go ahead and unscrew it and get the nut back...if you dont want too lose your warranty , i suggest you leave it in there..
I hope this helped but , Merry Christmas and happy new Year :)
Dec 23, 2009 | Logitech Z-5500 Computer Speakers
Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
Apr 03, 2009 | Logitech Z-5500 Computer Speakers
I am geting a distorted song in my computer speakers
What do you mean more exactly by "sound like if the computer freeze"? If you set wave or master volume on your PC too high, the sound card or the speakers may get overdriven, which results in distorted sound. So you could try lovering the voume in your PC, and set it higher on the speakers. (On the contary, if you set volume in your PC very low, and very high on the speakers, sound will get noisy.)
Mar 19, 2009 | Audio Players & Recorders
Install subs on back doors on a 95 suburban
Install Dynamat. That should stop the rattling and distortion. the distortion is from the door vibrating the sound waves and messing the sound molecules up before they reach your ears. stopping the vibration should stop the distortion.
Jan 20, 2009 | Insignia 600W Bridgeable Amplifier with...
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Logitech z5500 power problem
I replaced the fuse in the subwoofer. Solved the problem, without a hitch. Just take the current one out and bring it to an audio/hifi shop. Ask to buy a similar one.
PS. The fuse might look damaged, but then again, it might not. Have the audio/hifi guy test the current fuse, that way you know if that's the problem.
Oct 31, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
1,048 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
