Question about Barbie 11301 Mechanical Sewing Machine
I bought this at a sale and no manual. I don't know how to thread and what number needle we should use. Can you help me. Thanks
The Barbie Sewing Machine manual can be found here http://www.toyfinder4u.com/?page=shop/post&post_id=19
Posted on Jul 01, 2011
  • Barbie Master
  • 7,365 Answers
Try these sites they might have one
(pdf) manualsonline.com
sewusa.com
mastersewusa.com
sewingmachinesplus.com
homeappliances.manualsonline.com
please rate this with the thumbs in the upper right hand corner-thank you
Posted on Aug 06, 2010
When I press the pedal the string get tangled and I also have problems with the bobbin thread not being picked up! Please help! Thanks margaret
thread the machine correctly( follow the operators manual)
wind the bobbin properly and when placing the bobbin in the bobbin carrier pull the thread down the small slot and under the spring plate
thread for the needle always comes in from the left (The side of the groove in the needle ) and out the cut away side
pull a long piece of thread for the needle out and hold it while you turn the machine over
after 1 or 2 revolutions the needle thread will bring up the bobbin thread and you then pull both threads out a bit
if you don't have a user/operators manual there are 2 options
one is to go google and type in --user manual for bernina bernette model 65 sewing machine and down load the pdf version
the other option is to visit manchester shops ( cloth and fabric shops ) and talk with the sales people as may of these places have a sewing circle of people who will be only to willing to help you.
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
How do I tighten the lower thread on my 5710 Husqvarna please?
you need to change the needle to a ball point,, but check your
manual to see what needle it recommends
if you don't have a manual let me know & I'll check to see if I can
find one for you
adjust the top thread tension--if the bobbin thread is loose, then
tighten the top thread tension one number or letter at a time higher,
if the bobbin thread is tight,, loosen the top tension one number or
letter less..
take the bobbin out & reput it back into the bobbin case--make sure it's
turned the right way
Sep 29, 2012 | Husqvarna Sewing Machines
Where can I get a manual for bernette fun lock 006D
Serger manuals for early machines are really basic.
Thread in order.
upper looper, lower looper, right needle, left needle. (see the inside of the looper cover door.)
Adjust tensions to suit the fabric you are sewing.
If you need to change colors clip threads near the spools and tie on new spools to previous threads and draw threads through an already threaded machine.
Bernina is the brand. But I believe early models of the serger were made by Juki. I've looked for the manual for 006 as well and found thinging. Your only other choice is find someone who has one for sale and ask for a scanned copy.... or order a new one from Bernina or one of the other places that has one.
Aug 06, 2012 | Baby Lock Sewing Machines
Fix tension on Singer 4552SW
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight--if tension is too tight back
off one number or letter at a time, if thread is too loose increase
one number or letter at a time till you get the correct stitch
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8.also check to make sure the top thread has not come off the thread
take up lever
if you don't have a manual, & want one, singer has a free pdf
manual to download
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 4552) do not put in
the sw
Click search
Jun 05, 2012 | Singer Sewing Machines
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
Can someone help me with threading my Elna Serger?
A model number would be helpful
Follow the Colour Threading guide on the machine....
Basically......Start with the Loopers (from Right side) finish with needles (Left side)
So....4,3,2,1 in sequence .....1 is first then work to the left
Oct 19, 2011 | Sewing Machines
I have a Totally Me Singer Sewing Machine and I don't have an instruction manual. I don't know how to thread the needle on the sewing machine. If you can help this would be great !
Try this link: http://www.singerco.com/accessories/instruction-manuals Type model no. in the search field and press Search. You'll be able to choose to pay or download for free! Good luck!
Aug 15, 2011 | Singer Zig Zag 727198 Sewing Machine
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
Threading this machine.???
It really sounds like you have it threaded wrongly. You should find threading instructions in that manual.
Oct 23, 2008 | Euro-Pro 1100
Barbie 11301 Mechanical Sewing Machine Logo
112 people viewed this question
Top Barbie Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Barbie Sewing Machine Expert? Answer questions, earn points and help others
