Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
HT1000 Is HT1000 a trunking or professional radio?
    Brigadier General:
  • 6,966 Answers
Hi bonkuman,
To my knowledge the Motorola HT1000 is not a trunk system radio, it is as a "conventional" 16 channels two-way radio. Motorola classifies this radio as intended for Government & Enterprise. In my country, we call them "Commercial" radios as oppose to "Amateur" radios. In a way, yes they may be termed "professional" as their claimed performance and durability exceeds those of other radios. Incidentally, the Motorola HT1000 has been discontinued and was replaced with the PR1500.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 27, 2008
How do I program a HT1000 to have VOX capability?
Vox isnt part of the HT1000 you need the C6000 PTT-VOX Adapter Bodyswitch
Aug 13, 2014 | Motorola HT1000, MTS2000, MTX8000/9000...
I NEED HELP PROGRAMING MY HT1000 TO SCAN
Hi Ricky,
You need help programming your Motorola HT1000 to scan.
This is tricky, but I may have the solution you seek.
Join yahoo group Specific to your radio Make/Model, the team there will help you find the answer, plus you can download manuals, diagrams and other goodies (if available), for your radio, all this is free.
I hope your query has been satisfactorily answered.
Regards,
Peter
Oct 12, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
MTS non trunking made into a trunking system
Trunking radios are controlled by logging on to a central control - for use unless you have a trunking network with repeaters set up (costs a lot of money) stick to the non trunking versions - they can be reprogrammed to your frequencies and are very useable. without connection to a trunking network the Trunk versions would be better used as a door stop as they are very limited for re-use
Apr 30, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I FOUND A MOTORALA HT1000 ON THE SIDE OF THE ROAD AND IT IS PROGRAMMED FOR A COMPANY HOW DO I UN PROGRAM IT
The HT1000 is dealer programmable only. You should take the HT1000 to the nearest Motorola dealership and turn it in. It is likely they will be able to return the radio to its rightful owner.
Feb 16, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I need to get a manual for Ht1000 and ex500.
Unable to locate a PDF file for the EX500 or HT1000 online, however, here are the part numbers you can order by HKLN4118A for EX500 and 6881079C50 for HT1000.
Best regards.
Feb 10, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a motorola Ht 1000 i need to no how to program it with the keypad only...
The HT1000 is not keypad programmable. The HT1000 is dealer programmable using a radio interface box (RIB), cable, the appropriate Motorola propietary software. A sister radio named the JT1000 can be made keypad programmable with an accessory called a programming key.
Best regards.
Nov 29, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How culd i program a mt 2100
Needs Motorola software and RIB box.with programming cable $$ It is a very specialized professional radio for a specific use.
Oct 08, 2009 | Motorola For MT2000 HT1000 HT6000 GP900...
Need t know what the A, B, C switch on the Motorola ht1000 does
ABC switch = Function switch
Can be programming to many functions like sub channel or talk group on trunking radio or scan on/off, power lo/hi, repeater/talk around...ect......depends on what software allowing you to do.
Apr 12, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Working codeplug for MTz 8000
Only from Motorola or a Motorola Service Center. The radio requires all programming to be either programmed by a motorola dealer or by the owner of the the trunking system if they own the software for thier system.
Mar 31, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
115 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
