Can I get a copy of the Liberty Slant Fin L30 PT service manual for my routine maintenance and troubleshooting?
shastalaker7
  • 1515 Answers
SOURCE: Slant Fin SP90 furnace will not light. Pilot is on
Hi, If this green light is on a circuit board behind a panel, remove this panel to expose the led light. There will be a chart glued somewhere on the unit or panel telling you what this light is doing, lets say if it is flashing or steady or it flashes 2 times then 4 long flashes, go to the error code chart and it will tell you what is going on with the unit.Try this and get back to me and let me know what is going on please. I can go from there and solve your problem.
Sincerely,
Shastalaker7
PS The flame sensor next to the pilot may be dirty and needs to be cleaned. It is a ceramic rod with a metal tip and the tip should be cleaned with steel wool, not sanding cloth.Try this and see if it fires up. You could have a problem with your thermostat which we will get into next.
Sincerely,
Shastalaker7
Posted on Dec 28, 2009
SOURCE: Troubleshooting
the 2 digit are 34 but there is nothing in the manual about that error code.
Posted on Feb 25, 2008
Mix-it-up
  • 832 Answers
SOURCE: will not print
What 2 digit error code does the machine display, too?
Posted on May 12, 2008
SOURCE: Brother MFC 210 C.
I have the same problem and have no idea how to fix it. I tried pressing the menu button, then black start and then up arrow 4x but this just tells me that there is a machine error and doesn't give an error code. There's a bunch of maintenance codes I can type in but I have no idea what will fix the problem. I tried pushing all numbers from 1 to 99 and nothing helped. Anyone know what's wrong?
Posted on Nov 22, 2008
SOURCE: Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Posted on Jan 27, 2009
Slant fin doesnt turn on
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Jun 23, 2014 | Slant Fin Humidifiers
The ceramic coating under the nozzle deteriorating
Check this page out. It also has the owners manual listed. https://www.appliancefactoryparts.com/humidifiers/slant-fin/gf220.html
Nov 05, 2017 | Slant Fin Cool Mist GF-220 Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
How to clean the Slant Fin GF 200
http://www.appliancefactoryparts.com/content/pdfs/116637.pdf
Dec 10, 2007 | Slant Fin GF200 Air Purifier
ER3 Message
We had this problem and could not make it go away by refilling, jiggling the float and so on. All the controls appeared frozen during this time.
But unplugging the humidifier for 5 minutes and plugging it back in seems to have fixed it -- no ER3 message now (fingers crossed!0.
Apr 25, 2007 | Slant Fin Warm Mist GF-210 Humidifier
Lost instruction manual
Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: info@kaz.com also worth a look is: http://www.achooallergy.com/slantfin-operating-instructions.asp seems to be best forum for humidifier stuff
Feb 14, 2007 | Slant Fin Cool Mist GF-220 Humidifier
Heating & Cooling Logo
320 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
