Question about Ctm HS-2800 Power Wheelchair
Why would my less than 2 months old batteries die after 15 minutes run time?
    Novelist:
    Champion:
  • 232 Answers
Has your power chair been stored or not used in a while? Have you been charging the batteries regularly? Is the charger plugged in to a working electrical outlet, turned on and plugged into the power chair properly?
If the batteries have not been maintained properly, they may have become damaged that will prevent them from getting a full charge. It can happen quickly, even in as little as 1 month of storage.
When you operate the power chair is there any noise or vibration that could indicate a mechanical problem?
If you continue to have a problem, contact your dealer or manufacturer. If your insurance paid for the power chair, they may pay for repairs. Warranty may not cover repairs caused by customer neglect.
Posted on Oct 20, 2010
I have a 1989 Ford f150 drive for about 30 minutes it dies out or stop and want crank for about an hour
I would unplug the gas cap when it stalls; if you hear a hissing sound, change the gas cap, because it builds up a vacuum in the tank.
Old story??
1989 F150 dies when running wont start back for about 10 minutes ...
www.f150online.com/.../492401-1989-f150-dies-when-running-wont-st...
Nov 29, 2013 - Have a 1989 F150 with 5.0 bought truck about a month ago from original owner with only 89K on it. ... Took me about an hour to do a normal 15 minute drive, died and cooled about 5 times. ... Vehicle: 2003 Ford F150 ... It was cold when I put it on and after putting it on, started and drove for about 30 minutes ...
Sep 18, 2015 | Ford Cars & Trucks
Manual
old post
are you asking diagnostic advice,
or asking for manual or does manual mean stick shift
i toss coin
you wan the books,
click ack-faqs here , full 96 fsm there. book,manual
http://www.fixkick.com/index9.html
and tons more 600 pages there.
does it keep running if you keep charger connected
10amp charger ,not less.
green battery cables are first. lugs good, a must be......
Feb 15, 2014 | 1996 Geo Tracker 2 Door
1995 Olds Silhouette rattled badly, died while running
I think you had better have a local shop inspect this for a failed engine connecting rod.
Aug 23, 2012 | Oldsmobile Silhouette Cars & Trucks
Battery dies after a 2-3 months
First check your alternator voltage out put it should be 13-15 volts with engine running anything more or less then replace alternator.
Oct 29, 2011 | 1994 Nissan Pathfinder
It doesn't charge properly & also running on battery & Ac ,waht is the problem & how can I fix it?
First and foremost it sounds like a bad battery. Its very common to see laptop batteries go bad since they arent designed to last long. One easy way to test the battery is to simply unplug the AC adapter and see how long it takes to die. If it is saying 2:15 remaining, and 15 minutes later it says 1:45 remaining etc you know the battery is old and should be replaced.
Also, batteries arent supposed to be charged all the time, and leaving a laptop plugged in all the time will kill cell/camera, etc batteries.
Mar 01, 2011 | Sony VAIO PCG-Z1WAMP1 Notebook
Vehicle was parked and not started for 2 months.
Hi, there will be diodes in the generator that are letting the power from the battery drain away through the parked times when not in use. to prove it charge the battery- then disconnect the negative terminal on the battery, connect 24 hours later and see if the battery as kept it charge, if so - fit new alternator, good luck.
Feb 22, 2010 | 2001 Lexus ES 300
My laptop frequently going out of power for every 15 minutes it requires booting
By going out of power, do you mean the battery dies? Or is it shutting down even when it's plugged in?
Special equipment is necessary to check the battery of a laptop computer. The equipment will test the charging ability as well as the performance of the battery under the standard "load" of operating the computer. If yours is no longer holding a charge, or the charge lasts only a short period, it's very likely that the battery is simply worn out. Typically expect that if a battery is more than 2 years old, you'll be running out of life for it. Some batteries last longer, some much shorter. For example, Toshiba's Tecra series batteries seem to wear out and drain their charge quickly after about 6-12 months, needing a new battery.
If the battery is less than a year old, the manufacturers warranty may stipulate free replacement.
You may find a local computer repair shop that will test your battery for free since it's very simple for them to do.
Hope this helps, good luck!
Jan 12, 2010 | HP Pavilion zd8000 Notebook
93 astro van suddenly died
Check that connections are clean and check battery voltage with a meter...If battery has less than 12v in it, likely you have a bad alternator.
Jul 18, 2009 | 1993 Chevrolet Astro
Engine keeps dying
Time to switch to a low consumption car my friend
You are financing Terrorist countries such as Syria and Iran!
Jul 14, 2008 | 1998 Nissan Frontier
Ctm HS-2800 Power Wheelchair Logo
81 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Oloyede Monsuru
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
