Question about Lexmark X340n All-In-One Laser Printer
Svcerr faxControl.c 546: 900.xx pl.c 546: 900.xx fax init failed
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: faxcontrol.c 546: 900.000 fax init failed
    Hello Your problem could be due to an old version of firmware installed on your device. Go to this link. http://bit.ly/biqa0o and type in the keycode box in first this keycode 401ec4 that will download the newest firmware to your computer. Then to send it to your printer download the following from the same link just use this keycode usbflash that will download a usb utility that will help you flash the new firmware to your printer. The X340 needs to be connected to your computer via USB.
    Posted on Jan 27, 2010
    1270 e MAKING a shrill sound and screen says parameter init. Had to unplug to make sound stop. Still says parameter init when plugged back in
    It may need to be reset.
    Please try to unplug it. press & hold the menu/function key while plugging it back in. When lights are blinking release it then press 91. and then display will show parameter init then change to maintenance. Press 99. The display should show date & time.
    Hope this helps.
    Mar 28, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
    Low heat error for samsung sf-565pr fax machine pl help
    check the fuser heat lamp during initalize ,if heat lamp not glow then check the fuser thermostate
    if open then replace the thermostate.
    Mar 25, 2011 | Samsung SF-565PR/XST Printer
    My brother all in one printer givin init unable 49
    Init Unable XX:
    The machine has a mechanical
    problem.
    -OR-
    A foreign object such as a clip or
    ripped paper is in the machine
    Open the cover and look inside the
    machine for foreign objects and paper scraps.
    Then, disconnect the machine from the power
    for several minutes, then reconnect it.
    If it does not clear, you may need service:
    In USA: 1-877-BROTHER (1-877-276-8437)
    1-901-379-1215 (fax)
    In Canada: 1-877-BROTHER
    (514) 685-4898 (fax)
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jan 29, 2011 | Office Equipment & Supplies
    Scanner Error 6 Turn off than on, Tried that a couple of times and still displays the message in the window, cannot fax or copy but we can receive faxes.
    Sorry but I have a bad news. Scanner error xx means that the scanner lamp is not able to move and if it does it cannot go all the way by either something blocking it or a gear worn. In some cases it does like a humming or clicking noise. The printer need service, probably a new scanner. You can try an NV RAM: Turn it off and press the ''enter'' and the '' * '' (where the numbers are) while holding down both keys turn it on and keep holding them until you get the message permanent storage init and then release wait to see if it get back to ready. The repair might be too complicated and expensive (over $250) I suggest to get a new one. HP can provide a deal to recycle the unit and give you a credit, maybe not a lot but its something.
    Aug 26, 2010 | HP LaserJet 2840 Printer
    Faxcontrol.c 546: 900.000 fax init failed
    Dec 12, 2009 | Lexmark X340n All-In-One Laser Printer
    Needs time and date reset
    Press
    Function
    71
    set
    enter date xx-xx-xxxx
    enter military time xxxx
    set
    stop
    Sep 21, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
    I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
    1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
    * type sudo dpkg -i *.deb
    * Where is the linux source build directory that matches your running kernel?
    * [/lib/modules/2.6.20-15-generic/build] press Enter
    * Please enter region name for modem unit 0 [XXX] : type country name then press enter
    * Please enter your email address [unknown] : type your email address then press enter
    * Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
    * Please enter license key [FREE] :
    2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
    3. get key: XX-XX-XX-XX-XX-XX
    4. enter the key on Please enter license key [FREE] :
    5. Copy hsfpatch to /usr/lib/hsfmodem :
    * $ sudo cp hsfpatch /usr/lib/hsfmodem/
    6. Execute patch file : $ sudo ./hsfpatch
    * file 'modules/imported/hsfengine-i386.O' openend
    * patching... done
    7. Reconfigere hsfmodem : type sudo hsfconfig
    * Press ENTER for all the questions
    * Would you like to keep using them? [no]
    * Please enter region name for modem unit 0 [XXX]:
    * Please enter your email address [XXX@XXX.com]:Please enter
    * license key [XX-XX-XX-XX-XX-XX]:
    8. Reconfigure hsfmodem complete :
    * Config for modem unit 0: /dev/ttySHSF0
    * Device instance: 0-PCI-14f1:2f30-14f1:20d5
    * HW revision : Basic2 2.18 Standard DAA 3VoltsIA
    * HW profile name: hsfpcibasic2hsfi
    * Registration ID: XXXX-XXXX-XXXX
    * License owner : XXX@XXX.com
    * License key : XX-XX-XX-XX-XX-XX
    * License status : OK
    * Current region : XXX (T.35 code: 0054)
    * The /dev/modem alias (symlink) points to ttySHSF0
    9. Install KPPP
    10. Browse The World
    Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
    HP-3050 priter is showing memory low in time of fax
    Please perform the following:
    Super NVRAM init
    When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
    are undefined. The user is prompted to set the language and telecom country/region. Until these settings
    are defined, the all-in-one will not return to the Ready state.
    CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
    protected NVRAM memory.
    To perform a super NVRAM init
    1.
    Turn off the all-in-one.
    2. Press and hold down the * and 5 buttons.
    3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
    the entire power-on sequence.
    4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
    5. When prompted, set the language and telecom country/region.
    6. Allow the all-in-one to return to Ready before using it.
    Apr 25, 2008 | HP LaserJet 3050 All-In-One Printer
    Wont recieve fax
    NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
    Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
    Lexmark X340n All-In-One Laser Printer Logo
    395 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
