Question about Garden
I have a craftsman lawn mower and having engine problems. It will not start. I have tried cleaning the carb and opened all orifices, checked float and main jet. Everything is clear. I put it all back together and tried starting. NOTHING! It will turn over if I spray starting fluid, runs 2 seconds and dies. Any ideas?
  • David Burbee
    David Burbee Aug 06, 2010
    Hello! Tell me the year and engine size...Depending on information it may have a fuel pump...Disconnect fuel line at the carb. and crank the engine ...Do you have fuel? Send a comment... Guru......Saailer
  • Steve Aug 06, 2010
    Thanks for responding so quickly:
    It is a craftsman EZ3, 6.5 HP, Eager 1, 22" inch cut, self propelled gear drive. It starts with starting fluid, but only runs a few seconds. Fuel line appears to be gravity fed to the carb bowl, then a float keeps the fuel in check. Fuel and float are good to go. Thanks for your help!!
    Mower mod# 917.377271
    Engine# 143.976500
    I hope this helps. I have been racking my brain here to no avail
  • 1,871 Answers
Hello! Thanks for information...If you pull the fuel line going into the carb. and crank engine...Does fuel flow?...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on Aug 06, 2010
  • David Burbee
    Hello! Replace the fuel bowl...They are noted for warping...Part #730235B...It's a kit and should solve the problem...Saailer
My Craftsman lawn mower has a problem. After starting, it only runs a few seconds, and then dies.
There are a few things you may want to try. One, the float in the carb may be stuck. Try putting a small amount of gas directly into the carb, this may free the float. Two, try replacing the fuel filter, it may be that some fuel is getting to the engine but not enough. Three check the air filter, same as with fuel the engine may be getting some air but not enough to continue to run. Hope this helps.
Jul 19, 2011 | Garden
Mower ran out of gas now it wont start
Hi and welcome to FixYa, I am Kelly.
Carbs all have some minimal derbis in the float bowl. When an engine runs out of gas the float bowl cavitates and the debris that was just fine in the bottom of the float bowl is drawn into the main fuel jet located in the threaded area of the bowl nut. Remove the float bowl nut and bowl. Use carb cleaner to remove the debris from the main fuel jet orifice in the threaded area of the carb body.
(If the carb cleaner does not free the debris from the main fuel jet is can be unscrewed and removed for cleaning. Just make sure the screwdriver is a good fit to the brass slots of the orifice or you will never get it out.)
Make sure to clean out the float bowl and nut before re-assembly. This should get you going pretty quickly.
Thanks for choosing FixYa,
Kelly
Jul 10, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED LONG TIME. WOULD NOT START-CLEANED FUEL SYSTEM -GOT FRESH GAS. LAWN MOWER STARTED-HAS A HIGH IDLE NOW AND WILL NOW IDLE AT NORMAL IDEL SPEED. HOW TO...
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Oct 02, 2010 | Craftsman Garden
My 190cc, no primw, no choke engine stalls after a
Clean the carb bowl out. Check for water in fuel. While the carb is open check the float for obstructions and good volume of flow.
Make sure the float height is within spec. You will need to go the BS website and get this spec with your motors model and serial number. Normally floats are good when they sit level at the point the fuel stops flowing.
Good luck and be careful!
Jul 22, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Mower starts after priming, then quits. new sparkplug, air filter etc. cleaned bowl still no luck. cleaned out orifices in bowl screw. nothing. Suggestions?
Evan though you cleaned the bowl, the float isn't "floating" correct in the bowl to raise the needle for gas to flow into the carb. The float and needle can be replaced. When you prime an engine the gas shoots straight to the carb. As when the engine is running the floating goes up and down to raise the needle for gas to flow.
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
Craftsman lawnmower carb pours gas
One of two problems. your needle and seat is leaking or the float has a hole in it
May 30, 2009 | Craftsman Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
