Question about Acer Aspire 3003WLCi Notebook
Flick Screen My screen goes light and dark (quick flashing) would that be driver or LCD issue. When I attempt to turn on auto dim flash all the time does get dim, matches hard drive sound with a click!
    Scholar:
  • 154 Answers
Hi alex , first try to get the latest update for the laptop graphics adapter (start > settings > system tab > settings > than look at what graphics card is installed (display / graphics ) write down the type and brand and search via google for signed drivers (latest version) for your operating system and check if the display is set to the correct refreshrate (should be 60hz ) , some displays however need tot be set to 75hz. if this does not solve the flickering , search for a update of the auto dim feature. if this doesn't help either i guess it may well be a lcd problem with the signal cable it can be fixed but if there is waranty on it better bring it to your supplier and ask them to fix it instead of trying to fix it your self ..
Posted on Apr 27, 2008
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Televison & Video
I shut my computer down, I then traveled about 10 minutes in a car. When I arrived the computer had not been dropped and nothing hit it. When I attempted to turn it on it booted all the way. I could hear...
It is for sure that a damage is done on the LCD and it needs to be checked on HOW THIS HAD HAPPENED.
It seems that if the laptop was not shut but the LCD display door was made to stay OPEN while you were driving then the motion/vibration could have damaged the LCD or the linking wires to the LCD panel. Check carefully on the hinges of the laptop and see if there is any cracks. Also if there is display on an external monitor then the PC is working fine . You can open the laptop and ccheck if any connector of the LCD panel is loose. If no the LCD is a suspect and You must take an opinion from HP. Claim for warranty if the time limit is within.
Jul 13, 2011 | HP Pavilion dv4-1140go Laptop
Turns blue led light on ...quick screen flash then nothing...once it was so dim i could barely see anthing... like95% dark..i guess..also...can i take apart without breaking seal or something somewhere by...
Almost certain to be the screen inverter pcb locking up and going into protect mode Flea bay has lots of them relatively cheap and it's a straight plug in swap for the old one.
May 19, 2011 | LG M2362D 23 in. LCD TV
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Screen "Flashes" on/off
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 12, 2009 | Toshiba Satellite A135-S2276 Notebook
Aspire 6920 after power up, goes to black screen
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Acer Aspire 6920 Notebook PC
Imagines are dark even in bright light
the flash settings should have been kept in auto mode.if you want the flash always.normally, there is a button near the lcd screen, with the symbol of a lightning flash. when you press it once it sets the flash mode to auto, second time it sets it to "flash always on mode", third time "flash always off" mode.you can refer this process in instruction manual also.thanks for using fixya! please dont forget to rate my solution.
May 29, 2009 | Canon PowerShot EOS D60 Digital Camera
Presario R3000 display went dark can not see Screen goes black after a few minutes of use. You can see a very faint image after a few seconds, but you must do a soft re-start to bring the screen back....
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 01, 2009 | Compaq Presario R3000 Notebook
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Acer Aspire 3003WLCi Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
