My Polaroid HDTV, the screen turned blue i heard it was the capacitors but im not shure the model # is TLA-04841C and serial FR7B0215560001737 if you know whats wrong would you help me.
    Sniper:
  • 63 Answers
Might be the caps. Usually though you won't get any OSD-on screen display when it is the caps. Could also be the YSUS-Main.
Best regards and Semper Fi
Posted on Aug 06, 2010
Element tv dark no picture
This is a very common issue with that model. There are filter capacitors on the power supply board that fail and keep the back light power section from starting up correctly so you get no picture on the screen. The FLX-1910 uses the same power supply board of the Polaroid TLA-01911, below is a link to information showing how to repair this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
Nov 08, 2012 | Element Electronics FLX-1910 19 in. LCD...
Element tv turns on then goes off or freezes
That is a common indication of a failure in the power supply board filter capacitors. When the filter capacitors go out the voltages coming from the power supply fluctuate and cause all sorts of picture and power up problems. That model is actually made by Funai and is the same as the Polaroid TLA-01911c TV. They use the same power supply board which is the 200-000-xxxxtitx Here is a link to a repair guide for the Polaroid model that will be the same as for your Element TV.
I hope this information helps you out.
BuddyMc
Sep 30, 2012 | Element Electronics FLX-2210 22 in. LCD...
Polaroid tla 04841c polaroid screen comes on but nothing else will happen
The digital processor board to your TV has the fault. Troubleshooting this board is a very skilled work. Contact any experienced service technician.
Jul 10, 2012 | Televison & Video
My tv wont turn on
This is a common issue with this model. They used cheap components in the power supply board and these cheap capacitors fail and keep the unit from powering up. It is an easy repair to replace the bad capacitors with better quality parts and this should bring the unit back to life. Here is a repair guide for this model that shows what to look for and replace on the power supply board.
I hope this helps,
BuddyMc
Aug 29, 2011 | Polaroid TLA-01911C TV
I have on element flx 2210 22inch lcd tv and when i power the tv to on the little blue light lites up for say 5 to 10 seconds then goes out and changes to amber without coming on and when looking down...
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
I hope this helps,
BuddyMc
Apr 22, 2011 | Element Electronics FLX-2210 22 in. LCD...
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV - I seem to have the same
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
Oct 12, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Nov 08, 2008 | Polaroid TLA-01911C TV
Polaroid lcdtv flm-373b
its the problem in the power supply board of your tv. any of the capacitors or ic are loose on the board.check it out and make it proper,
Oct 26, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
