Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
When you pull the trigger it doesn't always start. If you pull it several times it starts again. I took the handle apart to look for a loose wire and didn't find any. I took the plug apart and tightened all wire connections in the plug.
  • 34 Answers
Sounds like the brushes may be worn and not working properly. Try replacing them.
Posted on Aug 10, 2010
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Dec 08, 2011 | Briggs & Stratton Power Products 5,550...
It has always started very hard and doesn't run
Mine is doing the same thing. I took it apart and had to take pliers to get it to retract. Just a cheap part.
Jun 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have 2 dewalt 18 volt hammer drills. The first one died about 2 years ago. The trigger seemed to mess up. I took it apart several times thinking I could fix it. I finally gave up on it. It's laid...
Hi, Take the drill apart using a star driver. When taking the chuck assembly from the yellow section have the drill chuch down to stop bits falling out. Once handle is apart popout the triggger assembly. Remove the two power leads from the assembly. Try a direct connection to the battery (polarity doesn't matter. If the motor goes it means that the trigger is U/S. Put a tester across the terminals (either set). You may have a short (as I had). It appears to me that the trigger is not user servicable. I used one from a DeWalt recip saw with a mod on the reverse lever. Works well.
Good luck.
Mar 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Every time I put the bike in gear it dies, also when I do get the bike to stay running and in gear when I get it to a stop sign it dies. Please Please help me.
Your clutch plates have become stuck together.The clutch needs to be pulled apart,clutch plates cleaned,and put it all back together in EXACTLY(EXACTLY) the same order as it came apart.There is plenty of people that know how to do clutches.Hope this helps
Jul 24, 2010 | 1983 Yamaha XS 400 L Maxim
I purchased the Wagner power tex and loved it, recently it doesn?t spray with the ease as it did when I bought, I haven?t used it a lot only to do fill in?s, seems like it only releases the texture once...
Your sprayer is self powered? you don't use a separate compressor? I have one with a compressor and it has to be taken apart " the gun" everytime or the trigger becomes stiff. If it's self powered, I would say your mixture is too stiff and water and it should be fine..If not and if it's self powered, then your motor may not work properly.
Mar 17, 2010 | Wagner Power Tex Texture Sprayer #0520000
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
No pressure HOSE IS BIG ENOUGH,NO KINKS, FILTER IS CLEAN. TOOK THE PUMP APART AND CHECKED ALL THE CHECKS, THEY WERE ALL OK.WHAT ELSE CAN I LOOK FOR? THE PUMP IS A KARCHER-MODEL G 1800 LB Thanks, Art
Brother Art,
Try this trick; it always works for me. Assemble the garden hose to the washer, install the HP hose, turn on the water. Now, make sure that there is no air trapped in the garden hose. Manipulate so as to direct any air trapped in the line to the washer. Connect the gun and continue to allow water to "free flow" for several minutes. Now, work the trigger, allowing the unit to rise to "house pressure, and then pull the trigger, dropping the pressure suddenly. This displaces any air hidden in the system. Do this several times, and start the washer up. If this doesn't get you up to pressure, repeat the above on an abbreviated scale, and hold the trigger on the gun down while you start the washer. This should do it.
Regards, --W/D--
Aug 08, 2009 | Karcher Garden
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Powermate pressure washer Model PW0872400
pressure washers has this pressure switches where in as you press on the trigger, the washer works and if you release it, the pressure would build up high and it would trip this switch to turn off the motor or deflect the water to the by pass hose ( if the motor is not stopping) then as you press again the trigger, water should come out of the gun again but would not,
i have encountered the problem is in the pressure switch, even the pressure went down, sometimes it wont close the contact then the motor wont run ,
if the motor is continously running, then the trigger switch is the problem, the pressure excerted on the switch is so high that even if you press it , it won't open up to release the water.
what i can suggest is to tie the trigger in the gun so that it is always pressed and then just unplug the unit if you want to stop using it. it is an inconvenience but it will work.
or, open the gun and see if you can figure out why pressing the trigger would not open the switch.
another option is you can lower the pressure of the washer if it has an adjustable pessure controller. by lowering the pressure might open the switch when ever you press the trigger.
i hopw i was able to fix...
good luck,
drcool
Aug 21, 2008 | Coleman (100076) Compact Refrigerator
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
76 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
