Question about E&B Giftware E and B Giftware Whistle-and-Find Remote Control Locator 3 pk
I HAVE A CAR EMERGENCY ESCAPE DEVICE WITH E&B GIFTWARE AS THE ONLY NAME ON IT. iT BREAKS GLASS, CUTS SEAT BELTS, HAS A FLASH LIGHT AND A SMALL RETRACTABLE PIN WHAT IS THE PRODUCTS NAME, AND COST?
Why does my dashboard lights flash on and off when I break? battery and oil light turn on red before car shuts off. car will restart but shuts off again after driving a short while and repeats.
Have the check engine light scanned for codes related to this problem first. You may have a charging system issue causing low voltage resulting in the lights flashing/stalling.
Jun 21, 2015 | 2001 Lexus ES 300
Panasonic dmc-fz18 camera.The Flash is always used, even if the flash cover is closed. I can see the flash light escape from inside the camera and hear a fuzzy click. Is it broken or is it a setting?
I have a lumix camera, more then likely it has gotten wet or it took a dive, here is what I would try, mind you! I'm taking a shot in the dark & this is a total "hail merry pass" first you need to get all the door type panels open, anything that flips up or open, remove the battery & memory card, buy some canned air for electronics & give it a good shot! do not use the compressor at the local gas station! particulate matter at high speeds is not good for sensitive consumer electronics, "like a photo device" figure a way prop & tip the device so that any condensation can rise & escape from the top, maybe it's your memory card slot? Let your common sence guide you, now your going to get a small area heater, turn it on HIGH HEAT & hold your hand in front. judge the distance so that it's hot, but you can still hold your hand there, without having to pull away.. I think you see were I'm going with this, My friend had a very pricey video production device, he had on loan, & it got just a tiny spray from the wake of a boat & it went in the dead zone. we though it was kaput'z! lucky we were in Arizona & did that trick, except we propped the device in the car in the garage, 12 hours latter, we turned it on & worked perfect! Best Wishes! I hope this helps? P.S. If that don't work & you want to go for broke "how brave are you? see that Lil Philips screw right by the flash?" it's 5% talent & 95% common since...
Feb 19, 2015 | Panasonic Lumix DMC-FZ18 Digital Camera
I need the Torque specs for a 2006 ford escape breaks front and back please
Pad material will cause these problems.... Buy good Cermic pads and new rotors and you won't have that problem
Jan 22, 2015 | 2006 Ford Escape
2003 ford escape seat belt warnign light
Probably no need to see an expensive mechanic. My seat belt warning light came on a few days ago when there were four people in the car and the rear seat belts weren't fastened (I thought that was why it lit up). However, the light came on and stayed on when I was the only person in the car. Logically, it suggested a bad connection somewhere, so I checked the connector under the passenger seat and made sure it was properly fastened together. I then sprayed a small amount of WD40 into the female clasps of both front seat belt connectors, clipped and unclipped the belts a few times and the light is now fine. Try it - it worked for my 2003 Escape.
Jun 03, 2012 | 2003 Ford Escape
Hi I have a 1990 acura integra and the alarm will not shut off. I am unable to locate the relay button....would you be able to tell me where it is?
IF you are talking about the seat belt alarm, and IF you have automatic shoulder belts (especially see the fuse section below):
Automatic Shoulder Belt Warning Indicator:
The warning light will come on if either of the automatic shoulder belts is unlatched with the ignition ON. The beeper will sound for approximately six seconds while the warning light is ON. Relatch the belt: the light should go off when the belt is latched.
The warning light will also come on while the shoulder belt buckle moves from its front off position to its rear locked position.
Automatic Shoulder Belt Malfunction Indicator:
The warning light will flash and the beeper will sound rapidly if either shoulder belt buckle stops before completing its full cycle
NOTE: If the shoulder belt's tensioner mechanism locks and prevents the buckle from moving fully forward when you want to get out, recycle the system by closing the door and reopening it. The buckle should move fully forward; if it does not, recline the seat-back and use Emergency Belt Release (button on top of the shoulder belt latch).
If the warning light and beeper do not function at all, or if they come on even with the belts latched and doors fully closed, it indicates a malfunction in the front seat belt system. In the event of a collision, severe personal injury could result. The system should be checked immediately by an authorized Acura dealer.
Proceed as follows if the shoulder belt buckle stalls.
1. Lift the hood and remove the cover from the engine compartment fuse box.
2. Remove the fuse for the automatic ("passive") shoulder belt buckle motor that does not work.
3. If the fuse has blown, replacing it with a new fuse of the same amperage should allow the shoulder belt buckle motor to work. However, if the fuse hasn't blown, or if a new fuse did not solve the problem, remove the fuse and operate the motor manually.
Oct 25, 2009 | Car Audio & Video
89 cougar ls seat belt light staying on, even when belts are work
The switch in the seat belt unit has gone bad. it will need to be replaced. no way to disconnect it that i know of.
If its disconnected, the car sees that as the switch being activated as if the belts are not being used.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 15, 2009 | 1989 Mercury Cougar
2000 S-40 Seat Belts cut into side panel when pulling in or out.
Most states have a department of automotive consumer affairs. I would check your state's online site's Department of Motor vehicles to file a complaint. The states are generally very good at helping the consumer on problems like yours. Let me know how they respond.
Thanks.
Jul 21, 2009 | 2001 Volvo S40
Seat Belt honda 1991
I was just looking at a recall list for 1991 Honda accords and the front seat belts not working so I would look up your car under recall problems and possibly go to a dealer to see if will fix free since is a factory recall. JOE
Apr 07, 2009 | 1991 Honda Accord
Grinding sound when step on break
Sounds like your brake pads/shoes need replaced. When the brake linings wear out, you have metal to metal when you step on your brake pedal. You may have to replace rotors/drums due to severe scarring.
Jul 12, 2008 | 2003 Ford Escape
E&B Giftware E and B Giftware Whistle-and-Find Remote Control Locator 3 pk Logo
97 people viewed this question
Top E&B Giftware Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E&B Giftware Toy Expert? Answer questions, earn points and help others
