Question about RCA Televison & Video
Have an RCA L26WD26D flat screen/DVD combo. After a period of time the audio begins to fade and I have to gradually increase the volume to the max to hear.
  • mjmouze Aug 07, 2010
    absolutely brilliant! Thanks much. regards-Frank
  • RCA Master
  • 11,800 Answers
It's a defective audio amplifier chip - either it heats up too much and its performances degrade or one of the capacitors from the reaction loop has aged and when it heats it's losing its isolating properties.
You need to open the case and test the amplifying IC. If you don't have any testing equipment then just unsolder all the capacitors and the IC, make a drawing of how they were, buy identical replacements and solder them back.
Posted on Aug 06, 2010
  • 1 more comment
  • mjmouze Aug 06, 2010
    What's an amplfying IC? It woulfd be easier for me to swap out the board the amplifier chip is on. Which one is it? How can I identify it by looking? Regards-Frank
  • Azrael SRL Aug 07, 2010
    IC = Integrated Circuit, the circuit that amplifies the sound. It's very easy to identify it, just look at the wires from the speakers, they should be plugged on the board very close to it.
    Yes, you can just replace the board but this is like junking a car because you have dirt on the carpets. Still, if this is what you want to do then this should be the board
    http://www.discount-merchant.com/RCA-CEF...
    I see several manufacterers of CEF276A boards-Are they configured alike-Are they the same?
Audio seems weak...how to increase volume
this is gotta be the largest complaint I hear from folks when they get a new flat screen , its not loud enough or the sound sounds muffled
flat screens are flat ! so theres no good way for mfg to put the speakers facing forward so sound has to hit the wall behind it first then gets directed forward to you ! (low/muffled)
sound bars help with this , but for true rich sound , id go with a video receiver amp combo , some of these even have built in dvd players , and arrange its speakers in a forward facing direction
Sep 16, 2015 | Samsung UN46C6300 TV
I need the code to get rid of the region code error on my RCA L26WD26D
I had exactly the same issue, and after a week of searching the web for the answer to this question. I posted a pdf of the page from the service manual that helped me fix the issue here: http://www.highdefjunkies.com/showthread.php/1817-The-Official-quot-Service-Menu-Access-Codes-Request-Thread-quot?p=353717#post353717
To fix mine, all i did was turn the volume on the tv to zero, then on the tv set itself, hold down the volume down button and on the remote control hold the number 4 button down both at the same time for 2 seconds. The screen will say "initialization of factory dvd data." and my dvd player started playing my dvd's no problem. I wasn't able to set the region code to a specific number like some people need, but maybe the answer to that question is some where else in the manual I posted above. I've spent too much time on this already :-D Hope this was a help and good luck!
Sep 08, 2011 | RCA L26WD26D 26 in. LCD TV
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
I have an RCA L26WD26D TV/DVD combo. It work great, until one day I turned on and there was no sound and a white screen. What can I do to repair my tv?
A white screen means that you are not getting any signal to your lcd screen. That is the job of the T-con board. The T-con board is located on the backside of the screen attached to it. You can get parts from www.interliquidparts.com
Jun 08, 2011 | RCA Televison & Video
Screen lights up sound OK, but large horz bars-with no video information. I disconnected the DVD player and TV is OK. I re-connected the player and TV is OK again...I don't know for how long, any ideas? ...
Mainboard (AKA tuner board) is the issue. It was lost with the DVD input plugged into the mainboard. IF this happens again, I would recommend unplugging the internal DVD and go with an external option. These combo tvs are confused because of the extra processing power needed for an internal combo player.
Thank you!
Apr 19, 2011 | RCA L26WD26D 26 in. LCD TV
Dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Feb 20, 2010 | RCA L40HD33D 40 in. LCD HDTV
My rca L26WD26D does not power on - using the remote or the direct power button brings about the same results. The green light comes on and clicking is heard, then the red light comes on. This cycle is...
The most common failures with LCD/ DVD combos is a failure in the DVD transport mechanism. The DVD transport mechanism is an easily replaced subassembly, that can be purchased for less than $200 in most cases. The best bet is t replace this mechanism ensuring that you purchase it from a vendor who will purchase it back if it dos not fix the problem for some reason.
In the event that the DVD player replacement does not solve the problem, the second most common problem is LCD's is the power supply module. Assuming that you do not want to have a shop repair this unit, search for a power supply module online and replace it yourself, ensuring you can return it if it doesn't resolve the problem.
There are other things that cause that symptom on LCD tvs that are beyond the scope of this discussion.
Apr 29, 2009 | RCA L26WD26D 26 in. LCD TV
RCA L26WD26D
sorry dear...just got disconnected
Feb 29, 2008 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
