Question about Maytag Neptune MDG5500AW Gas Dryer
Do not know hoe to get into the dryer to replace the drum belt
  • Maytag Master
  • 2,699 Answers
Unplug the dryer,open the door and take out the two phillips screws holding the door on and remove the other two screws opposite the door screws.remove the door and pull the front of dryer off.now remove the two top 5/16 inch screws and metal Lbrackets,down below them you'll see i think on the right side a screw that's in a hole or in a cutout,those screws are short and the one below it is a long screw on the bottom,don't take out anymore screws than that,on the other side the long screw is on top and the short screw is on the bottom and don't take out anymore screws than that or the bulkhead will separate on you,now pull the bulkhead off and you can replace the belt,when putting it back together just remember the short screws go into the cutout holes and the long screws go in the holes without the cutout.one more thing when you put the bulkhead back on make sure the felt isn't sticking out into the drum opening,if it is use a screw driver and push the felt in with it and push up at the same time and the felt will get pushed back up and behind the drum,run your finger around the drum and you'll be able to feel if the felt is sticking out
Posted on Aug 06, 2010
When dryer turned on a humming sound is heard, but the dryer does not start(drum does not tumble)
Links on how to change dryer drum belt below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Belt Replacement
How to Change Clothes Dryer Belt
How to Replace Dryer Drive Belt Repair Guide Help Sears PartsDirect
Feb 26, 2016 | LG Tromm Electric Dryer
Tip
Hotpoint Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Hotpoint Dryers
1970- 1990 standard capacity
Style: Flat with ribs
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
on Mar 06, 2010 | Dryers
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
How to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Apr 08, 2010 | Roper REX4634KQ Electric Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
My frigidaire dryer won't tumble
this belt you may want someone with experience.it does sound like your belt is bad but their is alot to go thru to put new belt on and if you never put one on before then it will be well worth spending a little.
Mar 09, 2009 | Frigidaire GLER642A Electric Dryer
Need to inspect tumbler, belt etc. Hoe do I get
Unplug the dryer.
Open the door.
Remove the 4 visible screws.
Raise the hinge side of the door and remove the door,
The front panel will pull out.
Remove 2 screws on the top right and left of the cabinet just under the top panel.
Raise the top.
You will also have to remove the front drum support. 2 screws right and 2 screws left.
Mar 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
192 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
