Question about Soyo DYLM24D6 LCD Monitor
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting stuck in an infinite loop locking up my Internet Browsers when trying to go to www.soyo.com. Did the company fold/go out of business? Was this monitor recalled? Do you have a contact phone number or new URL to reach the SOYO company by any chance? I cannot afford to buy a new 24" LCD PC monitor, really need the wide screen and size due to eyesight issues, so I would really like to get this problem resolved.
  • 1 more comment
  • dragonfx
    dragonfx Aug 06, 2010
    Yep, DVI cabling the first thing I checked, works flawlessly right now on my SONY SDM-HS95P 19" LCD monitor. Using same cable I've been using since I bought the SOYO back in November of 2008. The screen blanking is a new issue, just began about 2 months ago, is not getting worse and only goes blank during reboots or cold boots. Sometimes I get through the BIOS screen and Windows XP Pro goes black, other times I can hear Windows loading through my speakers but screen is blank as stated previously. It's as if Windows isn't recognizing the SOYO during start-up, or as if the monitor power supply could be failing, completely intermittent. I've been building computer systems for more than 21 years, for both US military and civilian markets. Current PC being used is one I'd built in 2007, DFI LP UT CFX/3200 DR based liquid-cooled gaming rig running Windows XP Pro. The SOYO monitor is on the same system and running on the same DVI cable I'd been using since the system was built, so it's not a cable issue.
    Thanks too for the SOYO bankruptcy information, I had no idea, and thanks for your time
  • dragonfx
    dragonfx Aug 09, 2010
    @ budmrtn:
    At age 52 now, I grew up in the Radio Shack P-Box Kits era, taught myself electronic assembly at age 7. Heath-kit and Lafayette Electronics kits next, I was building console TVs by age 12 from the component level. From there I went onto Certified Mil-Spec/ NASA Spec, N.S.A Spec
  • dragonfx
    @ budmrtn: At age 52 now, I grew up in the Radio Shack P-Box Kits era, taught myself electronic assembly at age 7. Heath-kit and Lafayette Electronics kits next, I was building console TVs by age 12 from the component level. From there I went onto Certified Mil-Spec/ NASA Spec, N.S.A Spec
  • 11,361 Answers
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Aug 08, 2010
  • 7 more comments
  • dragonfx
    For some reason this Site cuts off the bulk of my replies, limiting them to just a few words.
    I had typed a 500 word response only to have it cut down to a couple of sentences and no idea why.
    I will be back to comment just as soon as I'm able to dive into my SOYO and take a look-see, you have my word on that guys, if this Site allows full comment next time.
    With my extensive background in Electronic Assembly, these Links and comments should make this repair a simple task, saving me hundreds of $$$ too.
    MANY THANKS!!!
  • dragonfx
    Trying to post full comment again, here goes, hope it works this time...
    @ budmrtn:
  • dragonfx
    Nope, not working, Site still cutting my replies down beyond reason. Sorry about that. I'll do my best later to reply to my success or failure with the tips given. All my best, thanks again! ;-)
  • Bud Martin
    Bud Martin Aug 09, 2010
    I Google 'SOYO DYLM24D6 CAPACITORS' and lot come up: http://slickdeals.net/forums/showthread.... http://www.badcaps.net/forum/showthread.... http://lcdalternatives.auctivacommerce.c...
  • dragonfx
    dragonfx Aug 12, 2010
    I didn't think to look for bad caps, despite seeing this on old Mainboards before.
    I partially took apart my SOYO TOPAZ S monitor moments ago. Looking at the PSU board caps the caps all look normal. The large 450V cap top looks a tiny bit swollen but no signs of leakage, doesn't appear to be part of the cap repair kit. Two aluminum heatsink boxes are soldered directly to the PSB, over the caps. All solder joints have good fillets and appear well connected, including all chip caps/resistors
  • dragonfx
  • dragonfx
  • dragonfx
  • Bud Martin
    Bud Martin Aug 12, 2010
    Please send me picture so I can look closer at what you have.
    budmrtn@aol.com
    President:
  • 2,571 Answers
Yes, they went out of buisness.
Soyo Group filed for Chapter 7 bankruptcy with the United States District Court for the Central District of California, Riverside Division (case number 09-19355-RN), and ceased operations on May 5, 2009.
Have you checked all the leads and cables for faults?
Posted on Aug 06, 2010
Won't power up
Bad power supply board capacitor, most likely.
99.99% probability.
(the other .01% is it is not plugged in)
http://www.ebay.com/itm/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-/330499791194
Sep 03, 2013 | Soyo DYLM24D6 LCD Monitor
My monitor will not display a picture, every now and then my screen saver is on displaying the picture as if there is nothing wrong. Help
I just hooked up the Soyo moniter to my Dell XPS M1210 laptop and it won't display. I went to the Dell manual and it said to go to Start, click Control, Panel, click Display, Click Settings but when I go to the Display part the option is not available. Help please.
Jun 17, 2011 | Soyo DYLM24D6 LCD Monitor
Display screen is streched across monitor
it wiil lcd screen problem if can change lcd screen the problem wiil solve
Jan 27, 2011 | Soyo DYLM24D6 LCD Monitor
My Soyo 17" TFT monitor comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after about one second each...
Hi
Thank you for your query
Your monitors inverter has burnt out and will need your monitor replacing
I did not even ask for a bid for this as i dont think you should have to pay for a easy solution
Regards
Shauqat
Sep 24, 2010 | Soyo DYLM24D6 LCD Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Need drivers for windows XP Pro
If you have access to the internet you need to go on line and download them. I assume you don't have an XP pro disk?
In your control panel go to "system" "hardware" "device manager" Open your monitor and have it look for a driver. A website where you can download directly is www.drivers.com
Nov 08, 2009 | Soyo DYLM24D6 LCD Monitor
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
Soyo monitor goes dark every few minutes.
take it a part and look for swelled capacitors take out the bad ones and soder new ones in and then its back on
Jan 13, 2009 | Soyo DYLM24D6 LCD Monitor
Soyo DYLM24D6 LCD Monitor Logo
787 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
