Question about Maytag Neptune MDE5500AY Electric Dryer
How do you get into the dryer to replace the drum belt
  • Maytag Master
  • 3,053 Answers
Hello, labmom I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
I need to change the belt for my Kehmore Series 80 dryer
HI. this guide will help you replace this worn belt. make sure you have safely unplugged this unit before initiating this procedure.
1 From the top of the dryer, remove the lint trap. Using your screwdriver, unscrew the assembly that houses the lint screen and remove it from the dryer, setting it aside.
2 Using your screwdriver as a lever, insert it under the front right side of the dryer, between the top and the body. Press down to force the top slightly up from the body. Repeat this process on the left side, and lift the top off the dryer.
3 Remove the lower panel from the dryer by inserting the screwdriver into each side and rotating to release the clips that hold it in place. Slide your phone book under the now-exposed dryer drum so that the drum will be supported.
4 Loosen the screws at the bottom of the front cover, but do not remove them (this allows access to the belt without requiring you to remove and replace the entire front cover). Move to the top of the dryer, and remove the screws holding the front of the dryer in place. (These will be located at the top, behind the front.) Tip the cover toward you, exposing the drum, and slip the broken belt off the drum without fully removing. Slip the new belt over the drum, and lift up on the drum while returning the cover to the closed position. Replace the screws to the front cover and tighten the lower screws. Remove your phone book from its position under the drum.
5 Check the rear drum seal to the back of the dryer, and position the new belt identical to the old, with the textured side facing down.
6 Directing your attention to the motor area, remove the old belt and feed the new belt through, passing the entire belt, doubled over, under the idler pulley. Push the belt toward the motor pulley, placing the belt around it, and allow the tension to release on the idler pulley.
7 With your hand inside the dryer drum, rotate the drum counterclockwise to ensure that the belt has been properly installed. Replace the top of the dryer, exerting downward pressure for a snug fit, followed by replacing the lint screen assembly, and the lint trap, and then replacing the lower front cover.
8 Run the dryer for several minutes to ensure that the dryer is operational and that you have installed your belt correctly.
Aug 13, 2009 | Kenmore 64852 Electric Dryer
Best way to replace drum belt
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Asko T720 clothes dryer - thumping noise like the drum is damaged and shakes when going.
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Sep 13, 2008 | Asko Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
37 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
