Staples model SPL-TXC12A shredder. keeps running and stopping and running and stopping
SOURCE: Have a Staples SPL-XC200d Paper
I have the same shredder, and was wondering where you add the oil and what type you use? Would mineral oil work? I lost the manual, and I can't find any info online. Did you resolve your issue with the "add oil" light?
Posted on Aug 27, 2008
SOURCE: Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
Posted on Dec 15, 2008
  • 7 Answers
SOURCE: Have a Staples shredder SPL 1506X and need to find
no there is not
Posted on Jun 11, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
electrotech1
  • 1126 Answers
SOURCE: I have the Model SPL-QW120D
There is a door switch that might be defective and that is why it will not run, replace door switch.
Posted on Jan 02, 2011
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
What lubricant do you use for a Staples SPL-XC240D and where do you lubricate it?
Staples actually sells shredder lubricant. It comes in a small squeeze bottle. You actually are lubricating the shredder teeth themselves to keep them sharp and prolonging their lifetime. You simply take a piece of paper you are about to shred, run a bead of the lubricant across the sheet and feed it into the shredder. Done!
Mar 04, 2015 | Staples Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
752 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
