ASKO W6011 front loading washer. Door would not open with no water in machine. Opened door manually with cable release. Red light comes on with On button depressed, machine will not respond to Start button.
  • Anonymous Jul 15, 2008
    door will not open, no water in it
  • 641 Answers
SOURCE: "Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Posted on Aug 21, 2007
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
Lumpy816
  • 246 Answers
SOURCE: Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Posted on Jun 17, 2008
  • 5 Answers
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
Door of my LG washing machine(front load) is not opeining, Pls advise how to open it, Thanks
If there is water in the machine above a certain level, it will not allow the door to be opened.
To open the door, Open the hatch to the drain pump at the lower left front of the washing machine. If there is water in the machine and you can't put machine in drain, then you can detach the drain hose and drain the water into a container.
make sure that power is disconnected.
With the hatch open, remove the screws holding the red plastic handle in place. Pull the handle and the door will open. Put the handle back into its slot and put screws back in place.
Mar 31, 2011 | Asko W6021 Front Load Washer
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
Can't open door of ASKO W6883
If nothing else works, the washer door can be opened as follows:
This must only be done in an emergency
if the machine's glass door does not open automatically when the program has finished.
First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose.
Make sure that the main power switch is off and that the plug has been re- moved from the wall socket.
You will find the emergency opener for the glass door in the double sealed bag.
Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
Feb 28, 2011 | Asko W6021 Front Load Washer
Washing finished it's cycle and now the door won't open. Is there a manual overide to open it? How do we get our washing back?
If there is still water in the washing machine above a certain level, it will not allow the door to be opened.
Check the drain pump while you're there to make sure it is free of foreign objects
Feb 27, 2011 | Asko W6021 Front Load Washer
The washer will not open after a cycle completes
The Asko W600 & 620 series machines are designed in a way which if the control detect`s water still in the machine ( rightly or wrongly ) it will not allow the door to be opened.
Saying that, does the timer stop at "C" or "S" ?
I`d say obviously the first thing to check is the presence of water in the basket. You can open the door manually by first accessing the drain pump door located below the main door to the left. There you`ll see a small hose and a red colored ring screwed to the cabinet. With some towels close by and maybe a shallow cookie sheet, baking pan, open up the small hose plug and allow the water to drain out. Following this, unscrew the larger pump insert/button catcher. Now locate the small red ring I mentioned, unscrew the single torx screw holding it to the cabinet and pull it straight down, this should release the door lock.
If you still have trouble, let me know. I have a complete service manual I can send you if an email address is supplied. The file is a "pdf" and approx. 1.1mb in size ( pretty small, it`s mostly literature with some illustration`s for training Asko provided us techs. who are authorized servicer`s )
I`ll watch for your reply. If this was all you needed then please rate this solution accordingly.
Thank`s for visiting "fixya" and good luck going forward.
macmarkus :)
Apr 06, 2010 | Asko W6761 Front Load Washer
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
Mar 06, 2008 | Asko W6021 Front Load Washer
Asko W6021 front load washer door stuck! If any one can help me please do thanks, Dwayne.
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Oct 24, 2006 | Asko W6021 Front Load Washer
Washing Machines Logo
387 people viewed this question
Top Washing Machines Experts
