Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
Hello Rohan75,
I am not aware of any reset procedure for the Motorola T5500. The manual does not list any reset function. (Manual available via Motorola's website here: http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf)
From what you describe, it sounds like one of the units has some sort of hardware fault. It is possible that a simple reset (if there is one) may not fix this issue and the unit may need to be repaired or replaced.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 01, 2008
Oct 27, 2017 | Televison & Video
Jun 19, 2015 | Measuring Tools & Sensors
Jun 01, 2014 | Motorola Walkie Talkies 2-Way Radio
Apr 10, 2017 | Emerson LC320EM8 32 in. LCD TV
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Oct 03, 2009 | Kenwood ProTalk TK-3200U8P (8 Channels)...
Sep 04, 2009 | Olevia LT42HVi 42 in. LCD Television
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Jun 09, 2008 | Gateway 507GR PC Desktop
Feb 14, 2008 | Motorola Talkabout T5500 (7 Channels)...
Dec 06, 2010 | Motorola Talkabout T5500 (7 Channels)...
1,006 people viewed this question
