Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
It's not pumping bar oil. I've checked the bar itself and cleaned everything out. There's no oil reaching the bar. I'm not too familiar with where the pump is and how its supposed to work. Is it mechanically driven by the engine or is it a separate device? And, how do I get to it? Thanks, Doug
    President:
  • 2,220 Answers
Hello Doug.
It is a gear driven pump located behind the clutch. Find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
The parts list is very helpful with disassembly.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
3. Most (99.9%) clutches have left hand threads (tighten it to loosen it). If a finger nail held in the thread and rotated clockwise comes off the shaft it is a left hand thread. If it pinches against the clutch it is a right hand thread.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 06, 2010
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Nov 26, 2014 | Stihl Garden
I have a Stihl ms390 saw that is not oiling the bar but pumping oil out a 1/8" diameter port just below the muffler. Is this normal and just missing a plug. Does this condition sound familiar to you and...
The oil should be coming out of a port under the chain and bar cover. Remove that and the bar, there is a small hole there that the oil comes out of that should align with a hole in the bar. If it's coming out the front, something must be wrong. Make sure the one under the bar is clean, sometimes debris can plug it.
May 29, 2014 | Stihl Garden
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 19, 2013 | Garden
Bar oil will not go through were do i check for blockage
Remove the guide bar and clean out the delivery hole in it, flush the oil tank out with a suitable cleaning fluid and try again, if this does not work it may be an issue with the pump itself.
Jun 15, 2011 | Garden
Husqvarna chain saw 385 xp chain or bar not getting oil at all
check bar oil holes,
check oil tank pickup filter - should be clear, clean oil tank
remove drum and clutch, check drum and check oil pump driver arms ( could have worn or broken off and drum is not driving it around ,
check the worm part of the pump driver as well ,
remove pump oil pickup lines and outlet lines , check that both lines are clear and that the pump is not all bound up / stiff or damaged if everything else is good
i would replace the pump and reassemble , tighten clutch anti-clockwise ( clockwise to loosen it ) make sure drum cut out engages oil pump driver arms
as a rule if replace pump also replace pump driver , they are matched
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mh=10
slect your year from list and open up
cheers hope it helps
paul
Aug 11, 2010 | Husqvarna Chain Saw 20" Bar
Not getting any oil on the chain and the oil is full
Remove the bar and chain--clean the cover and case side. Start the engine and see if oil oozes out of the side port where the bar fits. Also, try the manual oil pump if it exists. If ok, clean the bar end oil-passages including the two channels that run from the large holes out to the chain groove on each side of the bar. Clean the entire chain groove, and check the tip sprocket for free turning. If no oil came out of the port, then remove the rear case which exposes the two tanks, the oil pump and the bracket that holds the bar to the engine. The oil pump runs by use of crankshaft impulses and has a diaphragm in the pump body that may be damaged. Also check the tank filter fitting. When you get everything back together, run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments of fast running. Hope this helps!
Jun 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No oil is coming out of my 044 stihl saw-I ve checked the crank - oil res if full -how do you adjkust the oil flow-the diagrams I've found don't fit my saw-
Stihl Product Instruction Manuals page 33
http://www.stihlusa.com/information/info_product2.html
You might also try
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 17, 2009 | Garden
Bar oil does not go to chain
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. Check the filter on the free end of the hose (manufacturer recommends annual replacement). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 16, 2009 | Husqvarna Chain Saw 20" Bar
I am having a problem with the oiler,getting oil to the bar&chain.
pump is probably gunked up! pour a dab of oil on it between cuts if you really have a task you need to finish up! then crack the case to the saw open and take a looksee
May 26, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
501 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
