Question about Samsung LN32B360 32 in. LCD HDTV
TV turns on and plays sound when turning on but screen stays black
  • 10,594 Answers
I disagree with given info.
LCD tv does not have any YSUS board inside.
I agree that capacitors can be cause of problem so check power supply board for bad/ leaky/ dried up capacitors and replace them with same ratings.
Check back light inverter board as well s they got failed and causes no image in lcd tv.
Posted on Aug 06, 2010
    Sniper:
  • 63 Answers
Could be bad caps or the YSUS board or a component on it has failed. I would go with recaping the bad ones on the PSB-power supply board first. this is the first signs of failing caps. Sound but no pic. When caps go bad they cut off the trace circuitry to the other boards they are connected to. Soon enough you won't even have sound, just a blinking fault LED at startup.
Best Regards and Semper Fi
4 Suggested Answers
  • 195 Answers
SOURCE: Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Posted on Oct 15, 2009
budmrtn
  • 11361 Answers
SOURCE: The sound stays, but the picture goes black after turning it on.
You may have the porblem with the power supply or the backlight inverter circuits, you need to check them out.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 23, 2010
gopakumarg43
  • 75756 Answers
SOURCE: tv turns on but screen stays black, all sounds can be heard when the cable box is turned on also
Yes. It is the fault with its back light inverter. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 24, 2014
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I have a 42 inch flat screen tv set only the blue and red led turns on nothing else the sreen stayes black my little girl played withremote cotroll from then it stoped working i think its on stand by
Find the settings menu in the TV. It sounds like you turned the green off completely. You can usually set the hues and colors and adjust for your preference or for lighting and such. Hope that helps.
Nov 17, 2013 | Televison & Video
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/shawn_b2b2e24a98865a53
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
Black screen and whistles
Sorry to say that it sounds like the high voltage went out on that one. The sound that you hear is probably the high voltage arcing across the flyback transformer. Dont try to make any repairs here. The unit has at least 25,000 volts in there. Even long after it has been unplugged. I'm not sure what size TV that is from the description, but you would be looking at replacing the main deflection board, which may well exceed the value of it.
Apr 13, 2009 | Televison & Video
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Samsung LN32B360 32 in. LCD HDTV Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
