Question about Philips HD-7810 Espresso Machine
Hi i have à senseo HD 7810 which i bought à week. R after running through the power up and forst time clearing procedure,The power light Doesjanbe not stay on. Therefore it is impossible to get it to create a cup of coffee. Can you please help? Kind regards Anthony
  • 24 Answers
You can repeat the cleaning procedure once more; there may be some air trapped in the machine. If that doesn't help, it's a warranty case I'm afraid.
Posted on Oct 28, 2010
How do I prime an old machine that's been sitting in my cupboard for awhile??
De-mothballing a Senseo check-list:
  • Get some citric acid & prepare it as prescribed,
  • Fill the Senseo's reservoir with the citric acid suspension,
  • Place a large bowl underneath the coffee outlet,
  • Press and hold both small buttons, and
  • Press the Power button.
The citric acid suspension will now be pumped through the machine, into the bowl. To stop the rinsing, press the Power button again. I suggest you repeat this a few times, don't forget to swap the pad holders somewhere in between so they both get some suspension as well.
After that, repeat the procedure a few times with fresh water only to get rid of any citric acid in the machine - it will make a poor cup of coffee if you forget that step!
Jun 19, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo HD-7810 Coffee Maker: how many uses can i get out of one coffee pad?...
Hi. They are only made for one shot, because the coffee will get weaker and weaker the more you use it. Also, it can compact and not let anything through.
The official stance from Philips on their website is this:
"We do not recommend this. The second cup of coffee will be rather weak. Also make sure the lid is closed properly, and do not press the 2-cup button if you want to brew only one cup."
May 16, 2010 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
Turned machine on this am,power light came on for a few secs,then went off...cannot turn on use my senseo every day...please help
Try another wall socket, and fumble a little with the wire - it may have been damaged. If you can notice a relation between moving the wire and the Senseo switching on and off, the wire should be replaced.
Nov 13, 2009 | Philips Senseo HD-7810 Coffee Maker
The water is not heating up!
Makesure the water holder is seated right. also follow the directions toclean it out once.
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Feb 01, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo coffeemaker 7810/15 is leaking water all over counter. Not sealing well?
Call senseo at 866-4-736-736 and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips HD-7810 Espresso Machine Logo
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
