Question about HP ProLiant DL165 G5 Server
I just tried to update the BIOS on my HP DL165 G5 with SP48069.exe, and everything looked good until the reboot. It will not boot now or do anything except spin up the fans. Help?!?!
    Scholar:
  • 106 Answers
When you updated the bios version, you missed updating the ipmi, and the ilo chipset, the mismatch in versions of these chipsets may cause the system to fail. There is not much to do here since there is no possible way to boot from a cd or usb to update these chipsets, however if it is possible to clear the settings from the bios it would be by clearing the cmos. if it works (chances are 50%) it will allow you to see post again and boot from a usb or cd if so have the smart start cd handy to go back to the bios you previously had.
You may need to clear the Setup configuration values (CMOS) if the configuration has been
corrupted, or if incorrect settings made in the Setup Utility have caused error messages to be
unreadable.
To clear CMOS
Locate the system configuration button (SW4) on the system board.
Press the button. AC power must not be connected.
or simple remove the cmos battery for a couple of seconds then put it back and
Posted on Aug 24, 2010
Hi, I did this with Proliant ML350 G5: 1. shut it down normally 2. installed some more memory 3. started it up with BIOS update CD in the CD-Drive 4. updated BIOS successfuly (according the flas...
step one after checking DC supply voltage to spec
is does the BIOS key works
BIOS must work or the system is dead.
or video out port dead.
is this your first PC failure? experience
see if this dead screen page helps.
your post is not clear at all
start at the power switch and then go into BIOS
can you do that, if not find out why, bad screen>?
bad VGA port? lost DC power, try 2nd known screen
we can see you work and what all you see or saw.
lacking more clear results, and tests.
http://jeepdied.com/look/puters/dead-screen.html
Mar 26, 2017 | HP Compaq ProLiant ML350 G5 Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
Hp pavilon dv6000 laptop won't start.it comes on (keyboard lights up and cycles on and off but won't stay on and boot up.
Could be anything but have you tried safestarting in windows. If it wont do this then the BIOS is lost. Use your recovery CD to reboot the system I had a problem like this and it was loose/blown memory module.
Feb 19, 2010 | HP Pavilion dv9000z Notebook
I have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Feb 09, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Hp dv9008 Tried to update the bios but somehow failed,now it
get it repaired under the limited warranty scheme
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Nov 08, 2009 | HP Pavilion dv9008nr Notebook
Cannot boot Linux Enterprise 3 on DL360 G5
It looks like you rebooted with the installation CD/DVD in the CD/DVD drive. Take the install disk out of the optical drive, and set the server to boot from a hard drive, preferably the hard drive with Linux installed on it. You can do it. I have faith in you.
Feb 02, 2009 | HP ProLiant DL360 G5 (457922-001) Server
Installing OSX 10.5 on G5 Mac Desktop Locks up
try to boot on 10.4, and then introduce de 10.5 DVD. Then the computer will ask to reboot, but with good options.
Jan 25, 2009 | Apple Power Mac G5 Desktop
HP ProLiant DL165 G5  Server Logo
469 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
