Question about Sony BRAVIA KDL-40V3000 Television
We have a sony bravia and use it daily sitting approximately 32" from the screen for TV and internet. IT GETS SO HOT THAT WE ACTUALLY START SWEATING WHILE SITTING IN FRONT OF IT....????? WHY DOES IT GET SOOOOOOOOOOOOOOO HOT AND PUT OFF SO MUCH HEAT!!!! ?
    Sniper:
  • 63 Answers
Its stuffed full of high voltage electronics that put out heat. Do you have proper air flow? Is the TV in a console or backed up to close to a wall? Very normal for them to put off heat. Should be able to feel it 6-8 inches from the screen. Overheating may become a problem in the future for your set... Check out your set-up and see if you could improve the air flow. Well just think in the winter you'll save on heating your place up... (((SMILES)))
Hope this helps
Best Regards and Semper Fi
Posted on Aug 06, 2010
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
I have a Sony Bravia LCD Flat TV. About 2 months ago small horizontal lines appeared. They are rainbow in color. Now many more have appeared...it is getting much worse. The plastic front is actually...
Sounds like the TV may be hooked up to a source with too much voltage, or getting overpowered in some other way. This is a safety hazard; if it's hot enough to melt the screen cover, it's hot enough to explode without warning. This isn't something you should try to fix yourself; call it in for servicing if you can. In the meantime, you should keep it unplugged.
Jan 29, 2018 | Sony BRAVIA KDL52XBR2 Television
My screen is cracked on my 32 inch sony bravia.is there a replacement scrren i can buy
Replacement panels are available for purchase, but in most cases it will cost more to replace the screen Vs. buying a new set.
Jan 13, 2013 | Sony BRAVIA 32-inch 720p LCD TV...
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
My new never used sony bravia lcd tv turns on then gets to the sony logo and turns itself off - can u advise please
there is problem with your tv power supply.there is main filter capacitor problem.check and replaced by same number.Number is menstion on the part look like (180uf/400v).
Oct 19, 2010 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Can you fix a cracked screen on a sony bravia 32 inch
HELLO
The answer is simple to this one....NO!
This is the main problem with LCD TV's when the screen is cracked a replacement screen will cost more than a new set.
Your only cure is a new TV!
Oct 20, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia LCD KDL52 TV: blurred picture with color bands
It is most likely the TCON board (located at the top right against the LCD panel). When these boards have problems, they can act up when cold or warmed up.
You will want to check with any extended warranty company you might have, or Sony's part website for the availability of the TCON board.
The problem here is, sometimes those TCONs are not made available separately and need to be replaced with the screen.
If you have to replace the panel, buy a new tv. You'll save yourself a costly repair.
Jul 14, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
MY TV WONT STAY ON WIDE MODE. wHEN THE ADVERTS COME ON IT CHANGES BACK TO HALF SIZE. I HAVE A NEW SONY BRAVIA
This is actually due to the signal format being sent down from the transmitters/broadcaster. They by defauly output 4:3 which your tuner in your TV interprets and rejigs it into 16:9. Te adverts as they come on are seen by the tuner in your tv as a change in aspect ratio, and therefore your TV is trying to best display these. However, if you go to your screen settings, you can change the screen auto format to your choice and this chould ensure that the picture always gets set to your choice. If set on default, it will vary between 'wide' and 'smart'.
Jun 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Need a Replacement LCD Panel Module for a Sony Bravia KDL-32S2000
I don't have a listing for the model that this is posted under, but the replacement panel for similar model KDL-32s2010 is $2232.55
I would expect the cost of your replacement to be similarly priced. If you post your specific model, I will attempt to get the exact price and part number.
Dan
Feb 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
