I am trying connect my laptop to LG XCANVAS LCD TV usign a HDMI cable. It used to work earlier but all of a sudden it stopped working. When i connect the HDMI cable the TV keeps showing no signal. Tell me what to do.
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
  • 90 Answers
SOURCE: Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Posted on Jan 14, 2009
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Posted on Oct 31, 2009
I used to connect my tv with my laptop using an HDMI cable, and all of a sudden, it just does not work anymore. What can I do?
Hi Cyril Lott,
There is a possibility that the HDMI cable might have failed so try connecting another known good HDMI cable and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Apr 12, 2015 | Dell Computers & Internet
Hdmi ports on 37LF7700 suddenly stopped working
glass magnifier and use cotton buds eletronic cleaning spray but be careful it mite just be dust or if you smoke nicotine either way or hoover if its dust
Mar 03, 2018 | LG Televison & Video
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
How can I connect my laptop to my LCD TV through HDMI cable (brand:LG) (model:LF15 series) HD ready?
You'll need to make sure that your laptop & LCD TV have an HDMI port. If they both do, simply connect an HDMI cable from your laptop to your LCD TV and make sure the input on the LCD TV is set to receive A/V from the HDMI port.
Jan 11, 2013 | LG Televison & Video
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
My LG TV and PS3 don't get along anymore!
Tries change all new HDMI cables,same prob.Tries RCA cable.
Nov 23, 2009 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
