Question about Garden
Sovereign sht 3400 primer bulb - Garden
2 Suggested Answers
  • 30 Answers
SOURCE: need sovereign hedge trimmer SHT 26 pull start
The agents for the Sovereign machine that you have aare Einhell.co.uk you can either phone them,(which I had cause to ) or mail them,but the spares are available as they order what you need,or do not have,rgds benji123
Posted on Sep 25, 2010
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
Otmail.com Buble thing at carburator has stuck in and will not come back out any advice
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
Jul 05, 2011 | Briggs & Stratton Garden
Need sovereign hedge trimmer SHT 26 pull start
Sep 02, 2010 | Homelite Expand-It Hedge Trimmer...
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
The primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Jul 18, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
I have a broken primer bulb for an Echo CS-3400 chainsaw. I need to replace it but am not sure how to remove the old bulb. I can access it but am not sure if it will be necessary to remove all the guts of...
You should be able to get to it if you just take off the cover that surrounds it. If you do not yet have a bulb purchased, I would reccomend trying the site I have below. I have also put the part number you will need to enter in the 'Search' box on the site to get the right bulb.
web site: www.m-and-d.com
Part #: ST-615-811
Mar 06, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
