Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
My coffee machine says decalcify ventilate - Saeco Royal Digital Plus Coffee Maker/Espresso Machine
  • 2 more comments
  • MitchellCorp Jul 02, 2008
    Hi I have the same problem, machine say decalcify
  • Anonymous Jul 11, 2008
    readout says ventilate
  • orendob Nov 07, 2008
    The machine is stuck on Ventilate and no Hot-Water/Steam can be dispensed.
  • Anonymous Dec 28, 2008
    how does this solve the decalcify message? I have used the decalcisying powder but message is there...
    Problem Solver:
  • 6 Answers
For ventilate:
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Posted on Jan 24, 2009
  • 515 Answers
Try to make a cup of water ( like you do tea), if it not work then you have to replace the magnetic valve inside the machine
Posted on Jul 11, 2008
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
  • 6 Answers
SOURCE: my coffee machine says "ventilate"
EsWorld
  • 1618 Answers
SOURCE: the machine has shown me with 'DECALCIFY VENTILATE' on the panel
Run the descaling procedure
Posted on Mar 09, 2009
EsWorld
  • 1618 Answers
SOURCE: Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Posted on Jun 03, 2009
  • 1089 Answers
SOURCE: how to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Posted on Jan 22, 2010
Why won't the ventilate message go away?
you have to decalcify your machine,but not sure will yuo can!!!
Jun 15, 2015 | Saeco Royal Coffee Bar Coffee Maker,...
What shall i do machine shows decalcify Ventilate?
Decalcify means that there's calcium buildup inside the coffee maker. You can buy stuff to put through it, but white vinegar works about as well. Fill the reservoir with vinegar, and start the coffee maker. You may need to run it more than once.
after it's run through, run 2 or 3 pots of clear water before you try to actually make coffee.
May 05, 2015 | Coffee Makers & Espresso Machines
I have saeco incanto coffe machine and when I have turned on the machine message appears Ventilate.
hi,probably your machine is need decalcify. Try to turn on the hot water knob when you start the machine. Fill about 1 water glas with hot water from machine.If the ventilate is still appear-you must decalcifying machine with special liquid for descaling.
Jan 04, 2015 | Saeco INCANTO DELUXE Espresso Machine
How to decalcify and ventilate the machine
Use diluted CLR to remove calcium, and then fill the water reservoir with vinegar, let this sit for a couple hours and then run the machine. Immediately run it again with water. Let it sit and dry for a couple hours and run water through it a final time before making coffee.
Mar 06, 2011 | Saeco Vienna Digital Coffee Maker,...
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Machine doesnt produce coffee
Try this, your machine has a manual/coffee grounds input, press the button for that option and see if water flows from the coffee spouts, if yes then adjust the grind on the grinder to coarser, if it gives you a ventilate error, then one of the lines to the brew unit is blocked, nd you will have to run the descale again or open machine and find blocked line and clear.
Mar 16, 2009 | Gaggia Titanium Espresso Machine
My coffee machine says "ventilate"
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate problem
Can you make a cup of water or there will only comes a half cup?
If you only get a half cup then you have to replace the flow meter in the machine.
Apr 27, 2008 | Gaggia Syncrony Compact Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
1,828 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
