Question about HP PLATES,CLUTCH LOCK 282249-001
How to remove and install clutch for 2003 IS300
When I place vehicle in reverse my right turn signal turns on
Remove bulb holder and clean all connections especially the earth wire's
Jun 23, 2016 | Lexus 1999 2000 2001 2002 2003 Is200 Is300...
Where is slave cylinder located on is300
i presume your asking about the clutch slave cylinder ,this will be located under the hood at the bulkhead end of engine compartment ,there will be a small fluid resovoir sitting on top of the actual hydraulic slave cylinder , the clutch fluid resorvoir is smaller , and usually not opaque, than the brake fluid resorvoir, which are usually next to each other , incidentally the brake also has a slave, or more usually known as the master , cylinder
May 13, 2014 | 2005 Lexus Is 300
Put my is300 on drive and does not respond when pressing gas
run fault codes and look for a TCM and torque converter clutch servo/solenoid problem
Dec 14, 2013 | 2003 Lexus IS 300
2004 lexus is300 transmission removal
Ned, Thank you !! No one has said how you get to those starter bolts for removal. We are going after it now.. My son blew out clutch and we are doing a father son repair. We have removed exhaust, drive shaft and most everything, but that starter has halted everything. Now to get the starter out.
That top bolt is not visible from any angle.
See attached pictures
Internet shot
Jan 28, 2012 | 2004 Lexus IS 300
I need to know how to remove lutch from kawasaki 65
1- Remove nuts, clutch spring plate and springs 2 Feed a rolled-up rag between both primary reduction gears to prevent the clutch from turning, then remove the clutch hub nut. 3- Remove clutch hub, pressure plate, steel plates and friction plates. 4- Remove clutch housing. 5- Slide clutch bushing and thrust water from shaft. Take care to note how thrust washer is installed.
Sep 24, 2011 | 2003 kawasaki KX 125
I am getting a P1481 code, From what I see it could be the Fan Clutch, but would it also cause it to shift at a higher RPMs, It only does it some time.
OK, loss of cooling fan speed. I will say this is plausible. I'll take your word for it (sometimes my online resource is not complete).
prev.gif next.gif Cooling Fan & Shroud Removal & Installation To Remove:
  1. Drain the coolant from the engine.
  2. Remove the air cleaner assembly from the engine compartment.
  3. Remove the air resonator assembly from the engine.
  4. Remove the inlet radiator hose from the radiator.
  5. Detach the transmission oil cooler lines from the fan shroud.
  6. Disconnect the fan clutch connector. Fan clutch removal and installation gm-03-00-1477.gif
  7. Use a J 46406 fan clutch remover and installer to remove the fan clutch from the water pump.
  8. Remove the upper mounting bolts from the fan shroud.
  9. Remove the fan shroud from the radiator by lifting the shroud and pushing inward.
To Install:
  1. Attach shroud to the radiator. Torque the bolts to 21 ft-lb (28 Nm).
  2. Use a J 46406 fan clutch remover and installer to install the fan clutch onto the water pump.
  3. Connect the fan clutch connector.
  4. Attach the transmission oil cooler lines to the fan shroud.
  5. Install the inlet radiator hose to the radiator.
  6. Install the air resonator assembly onto the engine.
  7. Install the air cleaner assembly into the engine compartment.
  8. Refill the engine with coolant.
Jul 22, 2010 | 2003 Chevrolet TrailBlazer
When I change the temperature in my is300 2001 it
temperature blend door actuator is the name and the little plastic gears has wore out you will need to replace two choices the lexus dealer or salvage yard you decide
Mar 21, 2010 | 2003 Lexus IS 300
How do i install a low beam headlight on a is300
back of light there is two bulbs they just twist out
Dec 13, 2009 | 2001 Lexus ES 300
How do I install a navigation dvd on a 2002 Lexus ls430 I did locate the dvd player but can't eject the dvd
the unit locks shut when disc is installed. there is a tab on the front that you must slide to open position, when you do this disc will eject. when you install new one you must slide tab back to lock position
Sep 23, 2009 | 2002 Lexus LS 430
Computers & Internet Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
