Question about Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was dripping enough water that the fan would start and the igniter switch would keep clicking, but, because there was no water actually on, it didn't light...so we had to power the whole unit off when we weren't using the hot water. So now the leak is fixed, BUT the problem is that the fan won't stop blowing when you turn it back on - and thus the igniter won't trigger if the fan is already on. Just can't get the fan to NOT come on when the power is turned back on! So we still don't have hot water. my guess is that the fan needs to be reset or something?? Please help!
  • 15,935 Answers
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Posted on Aug 06, 2010
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Posted on Jun 09, 2009
How to light the pilot light in a bosch aquastar 125 fx ng tankless water heater
I have the same machine first they said replace the micro switch i did then rebuild the water valve did not enough gas presure had it checked revented the unit the unit is brandnew relubed the water valve idk
May 11, 2014 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water at all when I turn on the hot water faucets nothing nomad I would hear the burner kick on but nothing what so ever
Before calling service tech, open following links for Bosch troubleshoot resources including phone support, error codes, possible manual.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
No error code can mean PC board failure, or plumbing problem
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 13, 2011 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Fan won't stop running
remove from the wall.... donate to charity and purchase a quality tankless water heater!!!
Rinnai, Takagi, Noritz are the only brands I will install. I refuse to even work on Bosch "Aquastar", complete garbage!
Aug 05, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Micro switch is clicking slowly
Likely causes are low water pressure, dirty inlet filter, dirty screen on faucet. If this does not correct the issue, contact Bosch for instructions on adjusting the micro-switch. You will need a very small screwdriver when you call.
Jul 16, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Aquastar 125b ng: after 2 years of use water is not hot enough
Sounds like hard water. Service the water valve. Parts are available from your local Bosch Service Provider (Contact Bosch if you don't know who the service provider is).
Feb 03, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Turn on water the electronic ignition not coming on
The tankless water heaters require larger gas supply lines because of the on-demand consumption. While I don't know your units rating, most Propane Tankless Waterheaters require 2" supply lines. Moreover, pressure is directly related to temperature which sounds like your problem entirely; consider the run of the gas pipe from the tank and the ambient temperature. Now you see why plumbing is a hard profession to fake... =)
Nov 19, 2008 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood Logo
184 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
