Question about Whynter SNO Arctica ARC-10D Stainless Steel Portable Air Conditioner
My AC sounds like a jack-hammer when it is on
Door saggs on my HD3500 work truck
Sounds like your hinge pins are wearing out. You can get a hing pin and bushing set either at the dealer or any auto parts store. You'll need a jack and a block of wood, or some rubber matting to protect the door. Open the door and place the jack under the door and raise the jack just enough to support the door. Using a hammer, I use a brass hammer but a steal hammer will work, drive the hinge pins out one at a time. With the hinge pin driven out you'll be able to see the wear in the hinge plate, then you install the bushings required to " realign" the pin holes and then reinstall the hinge pin. Sometimes the holes are badly elongated and on the later models were the hinge is welded I remove the door and build the wear area with a wire welder. The bushing method usually works well for most. Good luck I hope this helps.
Mar 29, 2013 | 1998 Chevrolet C3500
My compaq f700 laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the compaq f700 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 30, 2013 | Compaq Presario F700 Series Laptop...
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
When you plug in the ac the power is intermittent and then will go into hibernation. With a full charge the battery will last about 30 min. If you unplug the battery the ac will work for a short time then...
Sounds like you have a loose DC jack or a faulty AC adapter. Try testing the adapter with a multimeter (or have a someone do it for you) to see if it's output is consistent. If you wiggle the ac adapter plug slightly when it is plugged into the jack on the notebook and this causes the power to go on-and-off (you should be able to tell by a power/charge led on the notebook) it is likely the DC jack if the AC adapter tests ok.
Prices to replace the jack vary. My shop does it for $65 labor + $15 for the jack on most non-apple notebooks.
Sep 21, 2009 | HP 510 Notebook
Kitchenaid Dishwasher makes jack hammer sound when filling
Check the power to the valve actuator with a meter. If the power is not fluctuation (causing the valve to open and close quickly) then the problem is likely "water hammer" in the piping leading to the DW. Water hammer occurs when a fast flow of water turns a corner in the piping. The solution is too find where the pipe is vibrating and add support. Another way to eliminate water hammer is to install a shock tube on the pipe. It is filled with air and acts as a shock absorber when the water hammers. They are available at Home Depot, Lowes, plumbing supply places, etc. Another way to make a shock absorber is to install a tee in a horizontal part of the pipe with an 18 inch+ piece of pipe installed vertically and capped at the top. Air gets trapped in the vertical pipe and cushions the vibration. You might be able to do this in the space behind the DW before the pipe connects to the DW. The shock tube is smaller and does not have to be vertical so if space is an issue that may be the way to go.
Sep 18, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Sounds like a jack hammer
This is more than likely a broken gear in the motor area. You may be able to purchase a gear kit for the machine. Call manufacturer Customer Service. If it is a Fellowes product I gurantee we will help you the best we can.
Nov 20, 2007 | Fellowes 3011001 Shredder
Whynter SNO Arctica ARC-10D Stainless Steel Portable Air Conditioner Logo
226 people viewed this question
Top Whynter Heating & Cooling Experts
Oloyede Monsuru
Mohamed Ismail
Mohamed Ismail
gbob59
Are you a Whynter Heating and Cooling Expert? Answer questions, earn points and help others
