Question about Seagate Barracuda 7200.8 300 GB Hard Drive
Hard Drive Partition Table Error
I have this HDD that had stopped functioning in the midst of moving some files into it. When I restart the PC, the BIOS still detects it. But WinXp won't even boot. The blue screen came up, checking the drive for consistency and just hangs. Happens everytime. I can only get into the OS if i unplugged the HDD from the motherboard.
Ran Partition Magic 8 and it said that there's a partition table error #110. Tried using boot-up disks but they can't see the logical partition. The stuff that's mainly in the HDD are media stuff. And i know they are easily corrupted if using data recovery software post-formatting.
I'm wondering if there's a way to put the partition table back on the HDD and hence, i can move the files onto another HDD. The thing is, I can't even get into Windows environment with the HDD plugged in...
Thanks heaps!
Jason
  • Jason W. Apr 27, 2008
    Hey Boff.. thanx..
    But the problematic HDD was already a slave. Additionally, if it was plugged into the M/B, Windows won't load. It hangs.. The furtherest i can get to is in boot up DOS mode...
    Jason
    Heya Boff...
    The BIOS detects it, but Windows won't. The hdd is SATAII.. and dun think i can hear any R/W sounds from the hdd...
    The funny thing is, depending on how damaged it is, won't the System prompt you of an unformatted disk if the partition table is corrupted. As of now, the OS won't even load if the hdd is plugged in. Hence, i can't even format it or anything. But strangely too; that BIOS can detect it.
    jason
    Sergeant:
    Champion:
  • 333 Answers
If you have a spare HDD, you could install win xP onto that and set the problem drive as a slave. You may then be able to access the slave drive and save some of your files.
Posted on Apr 27, 2008
  • boff1 Apr 27, 2008
    Ah... You did not say it was a slave. Looks as though the disk is seriously damaged. Is the disk IDE? If so you may be able to access the data with a USB to IDE adaptor , if you have one, - after windows has started.
    Can you hear the disc spinning and the arm trying to find the fat sectors when you start windows? Can you see the disc in the BIOS?
    I think the bios will detect a bad disc but then everything stops when windows tries to load the operating system ,which is what you are finding. I have experienced bad discs that screw up windows but (fortunately) never a SATA disc. Obviously you won't be able to attach it to an IDE USB adaptor. I will do a it more thinking and let you know if I come up with anything helpful.
    When you managed to boot up in DOS can you see the files on your damaged disc? If so this could be a way out
    I wonder if a Linux o/s that runs from a CD would allow you to boot with the damaged HDD in situ?
    Cheers
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | HP Computers & Internet
Error message that says Drive is not accessible. The file or directory is corrupted and unreadable.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Hi , seagate 1tb Expansion portable drive S/H: 2GHY01LD error in page operation plz help
Go to Start, right-click on My Computer icon and select Manage
When you go to manage, select Disk Management.
Click on Disk Management and you will notice all the disks (HDDs and any removable devices on your right column.
Click on the Seagate 1tb HDD,
(1) Note the file system
(2) Note the Status of the drive
(3) Note Fault Tolerance
(4) Then Notice the HDD if it is Basic or Dynamic
If the HDD is Basic, right click on it and create a partition.
Then move some of the Data on to the new partition to free up the old partition. Restart the computer and abserve the results...
That usually happens when the Hard Disk driver is running out of space or you have less RAM..
Aug 23, 2011 | Seagate 1TB 7200RPM 64MB CACHE...
Hi, when I tried to upgrade/clone existing 60GB HD in Dell Inspiron 630m to HM160HC Samsung HDD, the HM160HC was partitioned to 60GB. I tried to fix the LBA to get back 160G but no success. I think only...
Hello Private672, Hi, If you have no important documents on the HDD or has been back up already, the full hdd size can be edited when you install another windows on it. there is a portion in the installation where you can delete and edit the partition. There are other free software utility on the internet for downloads to edit and low level your hard drive to get back the full size. among these are Partition Magic, Disk Manager. do a google search
Mar 02, 2011 | Samsung SA07HM160HC Samsung HM160HC 2.5...
File system error 1073741521
As per the error message you had received, I beleive that the File System (Partition Table) in your Hard Drive is curropted because of which you are unable to store any data.
The only option available is to burn the requried data into DVDs and perform full recovery and reinstall the Operating System to factory default settings.
This will format the Hard Drive and will also recreate the File System (Partition Table).
Oct 29, 2008 | HP Pavilion dv9000z Notebook
Hard Disk Partition
you have make Bookable floppy to boot & restart when it show 3 types you can choose without cd rom sopport and type fdisk then u can edit from there.
Sep 21, 2008 | Maxtor Hard Drive
Error reading patition table (MBR)
well am not 100 pct sure but i Guess u need to restore ur mbr /track 0 sector 1
Ntsnpr@yahoo.com
Sep 16, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
HDD data recovery
most hard drives have that erie only 2 partitians at a time this is with your computer how it can handle since you made three particians there is a chance that it only allows partitions of only 2
say for instance you have a celeron your comp would only allow what you memmory can give you this would knock out the 2 partician when created the 3rd partician
not enough memmory to fill all 3 partitians
safe end to this particians in long run can hurt your comp more than help it i suggest buying another hdd to make your back ups or get a portable pull out system hdd this ensures your files are as easy to get as putting in a new hard drive
hope this gave some insite
Apr 29, 2008 | Computers & Internet
Hard disk partition table error
Insert windows xp bootable disk and boot your system in CD/DVD and then reformat your HDD and install new windows operating system.
Jan 08, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
HDD error
I got the same HDD error on mine also. I removed the zif drive from the camcorder and checked it with an external zif hd adapter and the hard drive was good. I emailed JVC and asked them what is wrong with it they said to just mail it in for repair. I think it has to do with deleting the original hidden files and folders that were factory installed because when I checked the hard drive for folders it didn't have any in it(mistakenly deleted or moved). From what I have read from the manual you are not suppose to change folder names or delete hidden files. Hope this post helps you out a little. If you figure any thing else out post more info. Thanks.
Aug 26, 2007 | JVC Everio GZ-MG21 Camcorder
Seagate Barracuda 7200.8 300 GB Hard Drive Logo
1,091 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
