Question about Homelite Carburetor Trimmer Blower 308054001 Mightylite
I own a Homelite Vac Attack II Model UT08546. The unit is fairly new. It will not start. If I spray fuel into the carburetor it will run until the fuel burns out. I have replaced the hose and fuel filter in the fuel tank. I have also replaced the spark plug. Please help.
  • 755 Answers
OK! You know if you put fuel in it runs. You have replaced the fuel lines and filter which is great too. What is left? Two things....
1) fuel inlet screen inside the carb.
2) diapragm lever arm clearance.
Both of these are under the little covers on the carb. The one with four screws is the diapragm. The other will have one or two screws which is the inlet screen side.
Remove the gas from the vac and proceed to take the fuel inlet cover off.
The cover is under the air filter body so you have to pull the two star head screws out to get to it. With the fuel inlet cover removed you can pick out the screen inside the round hole and check it for debris/gelled fuel. These things plug at the drop of a hat! You can either try to clean the screen or go to a parts store and pickup a fresh one. I would go with a new one since the screens are so delicate cleaning is almost impossible. If you hold the screen up and look through it you will understand what I mean. You can also look on Ebay and order one and get it by mail. Which might be easier and still cost effective.
Once you replace the screen *(you put in the new by setting it in the hole and gently pressing it in with something blunt and about the size of the hole. It wont take much effort so be gentle. Once the screen is in put it back together, add a little fuel, and check the primer for rebound.
That is to say that the primer , once pushed in, should come back out quickly and fill with fuel. If it drags or stays in you still have a block somewhere in the system. This might mean removing the carb and stripping it completely and cleaning all the passages.
Do the screen thing first and we can discuss the diapragm work after that. Here is a link to homelite too:
http://www.homelite.com/service_support/order_parts
Posted on Aug 06, 2010
How to attach fuel lines
Hi coachnh
Check the drawing below, I believe this is what your looking for
Please take time to rate me
Bud
Oct 01, 2012 | Homelite Carburetor Assembly Vac Attack Ii...
I have run my Homelite Vac Attack ii using gasoline only. Now it wont run.
You need to take to shop and have them check it out, more than likely the cost of Repairs will exceed the price of a new Blower, In other words Yes this Motor is NO GOOD . Sorry For the Bad News..
Oct 23, 2011 | Homelite Leaf Vac Attack
I have a Homelite VAC Attack II that dies when you increase the throttle after it has warmed up for about 5 minutes. Any ideas?
Sounds as if its running out of petrol to the carb,have you checked for dirt in the tank,and or carb,failing that,you may need a new carb kit ,diaphram etc,they are available on ebay,rgds
Sep 26, 2010 | Homelite Leaf Vac Attack
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Vac Attack II - the choke plastic lever is not holding the on position. Not sure if a part of it snapped off or what. The spring is still on it but again it is not grabbing and staying up.
You will have to buy a new plastic lever and replace it. Or do what I do with mine, spray starter fluid in the carburetor to get it started.
Jim
Nov 23, 2009 | Homelite Garden
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 09, 2009 | Homelite Leaf Vac Attack
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
Homelite Carburetor  Trimmer Blower 308054001 Mightylite Logo
820 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
