Question about Daewoo Refrigerators
We've had a new fridge delivered, the Daewoo frsu20iai, how long do we need to leave the fridge standing before switching it on? Different people have told us different times ranging from 1 hour to 24 hours.
  • 4,793 Answers
Ideally leave it for 24 hours(but it wont hurt if you switch it on staight away)the standing time is to allow any air(gas) in the system to rise to the top of the pipes.besides it gives you time to check and level the doors,so that the seals fit flat all round.dont forget to cover/wrap all food in the fridge to cut down on condensation.root veg is best kept in airtight bags.
Posted on Aug 06, 2010
My Daewoo fr590nws is not cooling in the fridge compartment. the freezer compartment works perfect.
At a guess, I'd say the air channel between the freezer and refrigerator section is iced over. The easiest way to fix this is to switch off the unit, and leave it to defrost overnight. If the condition persists after this please repost your issue.
Dec 23, 2014 | Daewoo Refrigerators
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Aug 25, 2014 | Daewoo FRSU20IA Freezer
Daewoo american fridge freezer bad smell
look up the fridge on line or check the manual how the freezer is build. some freezers have a small space under the bottom of what you see as the bottom, where liquids can be trapped and haunt you for ever if you done lift the bottom part up and get under it. good luck
Jan 27, 2018 | Daewoo Refrigerators
DAEWOO FRSU20IAI FRIDGE FREEZER NOT FREEZING AT THE TOP BUT FREEZING AT THE BOTTOM AND FRIDGE IS NOT COOLING
I'V JUST HAD THE SAME PROBLEM AND IT WAS THE
EVAPORATOR FAN MOTOR . TOOK ME A WHILE TO FIND OUT BUT GOT IT SORTED . EASY FIX THOUGH .I FOUND OUT IF THE COMPRESSOR IS RUNNING THE EVAPORATOR FAN MOTOR SOULD BE RUNNING ALSO, OPEN THE FREEZER DOOR AND HOLD THE LIGHT SWITCH IN YOU SHOULD THEN SEE THE FAN SPIN . IF ITS NOT ITS BROKE. BEWEAR THOUGH AS MINE SPUN AFTER SWITCHING THE SUPPLY OFF FOR 24 HOURS BUT AS SOON AS THE FREEEZER WAS COLD IT STOPPED ALL TOGETHER AGAIN . MOTOR MUST OF BEEN BREAKING DOWN AT A CERTAIN TEMP!
Nov 03, 2011 | Daewoo Refrigerators
My Daewoo TV is stuck in standby mode
All you've got to do is get your remote and press the "stand-by button." As simple as that. Thanks
Sep 07, 2011 | Daewoo DTQ-20U4SC 20" TV
Fridge is not cold
Hi, This sound serious to me. I hope it came with a warranty if it is new. It sounds as though the compressor is not energizing when you turn the control up or down. Do you here the compressor under and behind the unit come on when you turn the control or nothing at all? Is the fan in the freezer working? Check to see if you have a door switch on the freezer that shuts the fan off when the door is opened first, and if so just open door and push and hold it down to make sure fan is on. If so, that's a good sign. With the control set at 4 it should be plenty cold. I would leave it overnight to see if the temperature drops and if not I would load it up and take it back for exchange. Or if it was delivered, I would take you're paper work in and demand a new one and not a repairman come out. You should have nothing at all wrong with this unit. If it was delivered, and it was layed down for some reason, that will burn out the compressor.I would do this asap. Good Luck,
Shastalaker7
PS I could walk you through a bunch of steps and things to take apart to check but it would void any warranty you may have. Get another new one.
Jan 30, 2010 | Refrigerators
Hi, my mum has just had a homeking frost free fridge freezer delivered and the delivery driver has instructed her not to switch on the appliance for up to 6 hours due to possible gas emissions. Please...
this does not sound right to me i have never heard of that kind of problem unless the fridge has been laid on it side for a long period of time then you should only have to stand it up for about two hours before plugging in to use it.there should be no reason why you can not use it now.i hope this helps good luck.
Jan 22, 2010 | Refrigerators
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
Refrigerators Logo
137 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
