Question about Dryers
The dryer overheated and my wife went in and smelt burning. i tore the dryer apart and checked everything out. i have my volts and ohms and i even tried to bypass the fuse and limit switch but still nothing so i am worndering what the next step is
  • 347 Answers
Sounds like a motor issue unplug unit get out the tech sheet and ck ohms reading of motor windings
Posted on Aug 06, 2010
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
I need help. Our dryer control currently works and when we push and hold the start button it doesn't start. lights work on control panel. door switch works and power is fine. last time it was used it smelt...
maybe the motor for the dryer, is this a even heat? if so here is a website:
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
if not an even heat here is another website:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer is not heating up, everything else is working fine. I have checked the door swith, and all the ducts are free of linen.
Thank you for contacting Fixya.com.
1) A burned out heating element. Remove tall box on right, element slides out from the bottom together with the "carrier". Look for broken coil, or check 2 terminals at bottom with ohm meter.
2) Burned wires at connectors. Check for obviously overheated wire terminals at all sensors (thermostats and thermal fuses in back), heater box, main terminals where power cord hooks up, etc.
3) An open thermal fuse. This is a small "thermostat" with 2 wires at the middle/top of the heater "box" (a tall narrow box on right in the back of the machine), or a plastic type on the duct close to the blower, depending on the model. You will need to remove the back cover of the machine to see these. Check with an ohm meter after disconnecting one of the leads, or jumper the 2 wires together to see if heater works (don't use this way though, fire hazard... replace the device) If this proves to be the cause of the problem, it would be wise to check all ducts and blower for excessive lint build-up. This will reduce air flow, causing overheating and blown thermal fuses.
4) Only getting 110 volts: This is often overlooked, but if for some reason one of the poles feeding the 220 power from the house wiring is open but the other is OK (for example, houses with fuses where only one fuse is blown, or a bad circuit breaker with one pole open). The motor and timer run on 110. If the side of the 220 line that feeds the motor is OK but the other one is open the motor will run but the heater, which 220 needs will not heat. Check for 220 volts between the 2 outer terminals where power cord connects or between the 2 "hot" terminals of the 220 outlet the dryer is plugged into.
5) Bad thermostats. There are usually 2 or more. A high limit on heater box, just above terminals on the bottom. 1 or 2 will be on the duct next to the blower. Check these with an ohm meter (or continuity checker). Some have 4 terminals; the extra 2 small terminals are small heaters inside the thermostats which alter its temperature characteristics. These will usually read around 4000 ohms or so. Check the 2 main largest terminals for continuity.
6) Bad centrifugal switch in motor. This is what actually turns the heater on, for safety reasons, so the heater cannot come on unless the fan is spinning. Otherwise without air flow past it, the heater would burn out.
There are 2 large gauge (usually red or yellow) wires going to the connector on the motor, these go to the contacts inside the motor that turn the heater on.
Also check the bellow link related to your issue:-
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Nov 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The fuel gauge doesn't work on my 95 F250
the sending unit could not have power or the fuse could be burnt out. Sometimes the sending unit does get stuck.
Nov 24, 2009 | 1997 Ford F250 SuperCab
Dryer getting hot
Dryers overheating is usually caused by a venting problem, but it sounds like you have the bases covered on that. I would look at a faulty high limit thermostat. It can be checked with an ohm meter to see if it is faulty. Hope this helped and best wishes.
Jul 29, 2009 | Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Motor smells on model lde7314ace
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
I have A kenmore Elite Model #110.65942400 Ser MR2103237.
before you take it apart make sure you have not lost 1 phase of the 220 volt line into dryer , dryers will run and appear fine on 110 volts be will not heat check fuse or breaker and re-set breaker even if it does not appear tripped , if fuse in line turn off power and remove fuses and check with an ohm meter , then if you have a volt meter check for 220 volts @ socket of dryer , then we will talk dis-assembly
Dec 01, 2008 | Kenmore 659 Electric Dryer
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
Oct 11, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Marvin
Marvin
