Question about Dishwashers
Telmann Dishwasher TEL 12DWM. Dishwasher started to make weird wooshing start-stopping sounds at the beginning of the wash cycle so I stopped it. Since then the lights are on but wont go regardless of where the switch is set to. Have pulled the pump off and the inlet pipes and blown to remove any blockage but still no luck. Cant get into the water jet part due to connectors that require specfic tools to remove and replace. Any thoughts?? thanks in advance, Michael
  • nickft Jul 07, 2008
    Dishwasher hadn;t finished cycle and was stopped then went to put washer on again and it won;t do anything
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
jmgldsmth
  • 1906 Answers
SOURCE: my MDB8951 dishwasher stopped working after interrupted the cycle
Go to your electrical panel and, disconnect the power to your dishwasher for about 1/2 hours when you repower it your DW should be reset
Posted on Jun 12, 2009
  • 132 Answers
SOURCE: Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Posted on Jun 14, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch diswasher water inlet work fine, when the
Hi, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. I have a copy of it at home and I can likely post it later, ( I'm on my iphone presently ) but essentially what it say's is this...Remove the pump fitler ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight or well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visitng "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not, again please let me know. Thanks again and good luck. Macmarkus :)
Posted on Mar 26, 2010
Testimonial: "Many Thanks! but motor still not running Impeller turning free"
LG washer makes start/stop sounds at beginning of cycle. Is this normal?
If it works and washes the cloths most likely it is normal.
Oct 07, 2016 | LG Washing Machines
How can I interrupt my dishwasher cycle without causing it drain out all the water and then have to start from the beginning?
Hey friend, thank you for the post!
From my understanding you are trying to interrupt your dishwasher cycle without causing it to drain all the water out and then have to start it from the beginning. Once the door has been opened the wash cycle will stop and once it has been closed again your appliance would start up where the cycle left off. Hope this is helpful - Matt
Jul 20, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
NO ON OFF SWITCH
Hello Heather, I know It is weird they don't have a on and off switch, but when the cycle is done it turns off. Turn it on by starting the cycle. You can stop the cycle by unlatching the latch when it is running. So like if you need it quiet, just open up the dishwasher door a little bit, it will stop. Close the door and it will finish washing.
Nov 14, 2012 | Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
At beginning of waswch cycle, water flows in. Then it stops and the cycle doesn't continue even though the countdown timer continues. Water flows out freely.
when the water comes in to dishwasher the wash pump should start if you hear a hummimg sound it means that the wash pump is either blocked or the capasitor on the pump is faulty or maybe the pump it self needs to be replaced
Sep 27, 2009 | Dishwashers
My MDB8951 dishwasher stopped working after interrupted the cycle
Jun 12, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
730 people viewed this question
Top Dishwashers Experts
