Question about Sony STR-D665 Receiver
Receiver goes into protect mode - Sony STR-D665 Receiver
4 Suggested Answers
remington870
  • 48 Answers
SOURCE: Sony STR-D460Z receiver
I have had this problem several times with Sony receivers in the past. The issue may be frustrating but these receivers are idiot proof. It is doing you a favor by tripping and not setting your house on fire as well.
Explanation:
Many things like improper wire crossing or touching due to too much of the insulation stripped off can cause this. Thunder storms and power surges as well have been known do this to Sony receivers.
Solution:
Unplug the unit and remove the cover. Look for any blown fuses as sometimes this is the problem. Take the fuse to a Radioshack to find new ones. However, it is likely you will need to take it in for repairs. This usually costs around $100. Find a local electronics repair shop in your area ( "TV Reapir in the yellow pages") or call Sony to send it to them.
I hope the latter works.
Posted on Mar 31, 2009
  • 92 Answers
SOURCE: goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
Posted on May 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sony STR-DE185 receiver powers up, but then goes
"Protect" is what it does when it senses a dangerous condition.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
Stay in protect mode very offen, but if the receiver start, he work well !
Check if the speaker cables have no loose cores touching the chassis of the receiver. Mostly this is the reason the receivers goes into protection mode.
Jan 26, 2016 | Audio Players & Recorders
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
When swicth on, it goes out after writing protect, can i do anything?
It goes into protect mode when it senses something wrong. First check the speaker wires for shorts or diconnect them as a test. Turn it on, if still in protect mode, the problem is internal and needs to be looked at by a tech/repair shop.
Mar 09, 2010 | Sony STR-DE497 Receiver
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
Protect appears on display on kenwood kdc 3034
Disconnect all the speaker wires at the receiver and turn it back on. If itdoesn't go into protect mode, your receiver is ok.
Reconnect the speakers one at a time being sure to turn the receiver off each time you connect a speaker and turn the receiver on until your receiver goes into protection mode again.
When it goes into protect mode again, the last speaker you connected has a problem. Trace the speaker's wire to the speaker looking for cuts or shorts along the way.
If you have a multimeter, switch itto ohms and check the speaker for a dead short, if you show a dead short you have a blownspeaker. Hope this helps.
--Matt
Oct 07, 2009 | Kenwood Car Audio & Video
Goes into protect mode..
May 17, 2009 | Sony STR-DG520 Receiver
Unit goes into protect mode
Not unless you know how to troubleshoot solid state electronics. If you disconnected the speakers and the unit still goes into the protect mode, most likely you have a short in one of the power output stages. Good Luck
Jun 03, 2007 | Marantz SR-4200 Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
