I have an old Canon S9000 inkjet printer. The yellow cartridge suddenly does not produce ink (it's half full), so my prints come out the wrong color. I have done the deep clean routine, but it hasn't helped. Is there an easy fix?
SOURCE: Canon iP90 Printer Ink Issue
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Posted on Jan 03, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
Dipu007
  • 2110 Answers
SOURCE: On Canon S9000 A3 inkjet
1. Turn off power.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Posted on Dec 04, 2008
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
  • 1626 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
Printing wrong color
You must do a deep printer head cleaning on your unit, it could be clogged and dirty and that because it will not produce or print out a proper color.
Let me know here again.
Dec 11, 2009 | HP Photosmart 8150 InkJet Printer
All of the sudden the color does not print properly on my canon I850 - its washed out and orangish
Check the color cartridges, especially the yellow. If the yellow looks llike orange or brown then the ink is contaminated. It happens when the printhead goes bad. A membrane between the colors breaks allowing the inks to contaminate each other.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Printer prints wrong colors
As a guess you have the color ink cartridges in the wrong places. Take them out and run a whole bunch of head cleaning routines. I'd expect the wrong colors for a while until the incorrect ink has been flushed out.
Check your manual or setup guide for the actual order . Usually black-cyan-magenta-yellow
Jul 09, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Color ink cartridge does not print in full colors
Canon printers do not like the refilled ink cartridges. After having ruined a few printers trying to "save" money. I went back to genuine Canon ink and have never had a problem since.
Jun 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Printer problem
Hi , did you check nozzle what color appear , some ink cartidge are old stock and dry , pullout cartridge clean the contact nozzle .
Feb 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
k24674
jasbo
jasbo
Marvin
Marvin
