Question about Apple iPod nano 3rd Generation
It said connect to power
The apple is not  coming up when i press the buttons it did say connect to power ..Its flat and wont charge its been connected to the usb cord thats plug in the computer for a couple days. nothing comes up on the screen of the ipod, u cant see it in itunes.
  • ashiz May 20, 2008
    my ipod wont charge when plugged into the computer. I have tried to leave it in for hours to boost it up, but it says the device wasnt recognized at all. I even bought a new husb cord, but that isnt the problem!
    HELP ME PLEASE
  • sharkazach Jul 06, 2008
    same problem. USB is plugged in, and the Ipod won't charge because itunes isn't recognizing anything plugged in.
  • 6 Answers
First off....DO NOT connect to a USB Hub. DO connect directly to your computer.
Second off...I had exact same problems as listed above so I looked in the manual and it says:
Slide HOLD button to orange and then back to white. Then HOLD the MENU and CENTER button at same time until Apple logo appears.
Worked for me.
Posted on Jul 05, 2008
Worked for me.
Posted on Aug 03, 2008
Just connect to the computer and click restore.
Posted on May 19, 2008
    Problem Solver:
  • 9 Answers
Try getting a wall charger and charging it from the wall
Posted on Apr 28, 2008
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
My ipod is disabled and it wont let me put in my passcode when i get to itunes. So i cant listen to my music i need help. i cant live without my music!!
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
You will lose all your data though...
Sep 07, 2009 | Apple iPod touch
When i plug my ipod touch into the computer this comes up..HELPP
Sep 06, 2009 | Apple iPod touch
My ipod is disabled and my computer wont let me fix it
you can reset its password....but you'll lose all your data. Here's how...
Sep 05, 2009 | Apple iPod touch
Itouch is diabled someone put a password on it and all that comes up is the number pad for the password. will not connect to itunes either
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 13, 2009 | Apple iPod touch
When I connect my ipod nano 4th gen to my PC it won't appear in iTunes or in My Computer... What do I do to fix it?
These directions are taken from Apple.com.
Putting iPod into Disk Mode
http://docs.info.apple.com/article.html?artnum=93651
"1. Before manually placing the iPod into Disk Mode you should verify
that it has a charge, if not you need to either charge iPod before
continuing or connect it to power. You can either connect it to a
high-powered USB port, or plug the iPod Power Adapter into an
electrical outlet and connect iPod to the power adapter.
5. Disconnect iPod from the power adapter and connect it to your
disconnect"
If you are having difficulty putting an iPod model with a Click Wheel
into Disk Mode, set the iPod on a flat surface. Make sure that the
finger from the other hand to press the Play/Pause button."
This of course can also be used in reverse to switch from Hard Drive
mode back to iPod mode.
Oct 03, 2008 | Audio Players & Recorders
hi :) uhmm, try to press the menu button and the center button at the same time. this happened to first ipod, a nano also, and it worked. hope this helps :) and i know how you feel emily , teehee :)
Sep 14, 2008 | Apple iPod nano
My IPOD is froze up!!!
this procedure normally works for me::
disconnect"
Jan 19, 2008 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
4,792 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
