Question about McCulloch 10" Electric Pole / Chain Saw
How to replace fuel filter on pp445 poulan pole saw
    President:
  • 2,220 Answers
The fuel filter is on the free end of a hose inside the fuel tank. Insert a hooked blunted wire through the filler port and gently withdraw the hose.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 06, 2010
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
I am replacing the fuel lines on a Poulan 446 Pro Pole Saw. The two hoses inside the tank are completely dissolved away, so I don't know how much length to put in the tank. There is a 3/32 x 3/16...
Bill, the small hose connects to the fuel filter inside the tank feed the
hose thru the tank and pull out thru the filler hole and insert the fuel
filter, pull hose back to outside until you have 4" of hose in the tank
with the filter. this same hose connects to the bottom (shorter brass
stem to carburetor). the larger diameter hose will fit 1/4 " into the tank, and fit to the top (longer brass stem)
May 14, 2011 | Poulan Garden
Poulan 2375le chain saw. just replaced primer bulb, gas lines and diaphram. also has new gas and spark plug. will fire up but wont stay cranked especially when I mash the throttle. please help..
Check the fuel filter, air cleaner and muffler for plugging. Be sure the fuel and oil mix is thoroughly shaken just before filling the tank each time to prevent oil starvation. Set the plug gap to 0.020" and test the spark for being blue and snappy. If weak looking, remove the left side engine cover to expose the flywheel and ignition module. Turn the flywheel so that the magnets are just under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the poles to contact the magnets. Tighten the screws, turn the flywheel somewhat to remove the card, then turn the flywheel one full turn to make sure the gaps don't close up further. Replace the cover and retest spark--if ok, try for start. Hope this helps!
Nov 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP446T Pole Saw. Will run only if choke is fully closed. Open the choke and it stalls. Have replaced the fuel filter, cleaned carb, installed carb kit. Cleaned gas lines. Good gas mixture(other saw...
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Jan 22, 2010 | Poulan Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Jun 16, 2009 | Poulan Garden
McCulloch 10" Electric Pole / Chain Saw Logo
209 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
