Question about Sony Cyber-shot DSC-W110 Digital Camera
I am a proud owner of DSC W110 Sony Camera. It has stopped to flash! From the menu I observed Flash is "Off". Attempt to change it to "On" is without success! Also I have a fault "E:91.01" always flashing. Pls. help me out! Tam Theophilus
  • 455 Answers
The E:91:01 error code indicates an issue with the malfunction when flash is being charged. It may be required to change or check the flash unit with the Sony Authorized service technicians. Try the following troubleshooting steps and check if the issue can be resolved:
Power resetting:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory resetting:(This can be performed only if the Menu is accessible)
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
If the issue is not resolved after trying the above troubleshooting steps, service may be required.
Posted on Aug 07, 2010
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
My Flash Won't Work I Am Trying To Do Everything,
If it doesn't work in the Auto, could be a bad flash board, lamp or dead fuse on the main board. You should contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Jul 18, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I have a DSC W 110 sony cyber shot digital camera...since some days its flash would nt work and an error msg E 91 01 is showing up on the screen..i tried reseting and initializing it many times..but all in...
Hi!
E:91 is a flash error. The flash fuse on the main board or the flash board is bad. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
Tom
Jul 10, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Hi!
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
When is on AUTO wont shoot with flash.I have sony dsc w 110
It will not because the AUTO mode decides if you need a flash. Look for a flash with an X through it. That means you shut it off. Turn it on.
Mar 04, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Sony Cyber-shot DSC-W110 Digital Camera Logo
371 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
