Question about LG Televison & Video
I have an lg lcd tv model no.-22lh20r. how to upgrade its firmware?
tvtek
  • 1284 Answers
SOURCE: RCA LCD l46wd22 failed firmware upgrade
You probably want to contact RCA technical support. As far as I know though there is no force that you can do and most likely you will have to replace the main board. Anyway contact RCA technical support. Was there a particular reason you were updating the software?
Posted on Nov 21, 2009
  • 5 Answers
SOURCE: is there a firmware upgrade for a tevion elite 47
hi, i was having trouble with freeview signal being very poor and could receive only a few channels problem was found to be the tuner in the tv, got in touch with aldi who got in touch with the local engineer who informs me all the tevion 47" tvs require a board upgrade due to the problem with the freeview, board has to be sent away for the upgrade to be carried out goood job mines still under the 3yr warranty
Posted on Dec 09, 2009
omaharox
  • 166 Answers
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Posted on Jan 18, 2010
SOURCE: Multisys. TV NTSC tuner to PAL conversion, Brand LG,
i am using a mini multisystem modulator i fixed inside the tv.i used the s-video input of the tv to connect the output of modulator i.e AV -OUT.it works via remote sensor of d mdlt positioned at the IR of the tv.
Posted on Sep 08, 2010
SOURCE: Is there a way to
I have same issue here 37lh50yr . need to update firmware
Posted on Sep 30, 2010
I WOULD LIKE TO UPGRADE THE FIRMWARE ON MY SONY KDL40EX400 LCD TV.I BOUGHT THE ?FLASH DRIVE FOR IT. HOW DO I DOWNLOAD THE INFORMATION ON TO IT?
You must go to the Sony website and answer the questions about your TV. Model number etc. Then go to support and input your model again. Look for software/firmware upgrade and it should take you to the firmware upgrade and download for your Model number. Download the firmware upgrade "INSTRUCTIONS and the firmware to your computer. Then plug in a blank formatted USB flash drive into your computer and transfer both the instructions and the firmware files to the flash drive. Be sure to unzip the firmware files on the flash drive. Print the firmware upgrade instructions so you can have them there when you are ready.Special Notice!!! Read and really understand the instructions and follow them to the tee. Do not power off the TV or unplug the flash drive while the TV is upgrading the firmware. Let the TV finish.
Nov 11, 2017 | Sony Televison & Video
How do I upgrade my LG LH 20 lcd tv firmware
As far as I can see on the support page, here: Product Support
there is no firmware upgrade. An upgrade is only made, when several people have a issue with there device, and it can be solved by upgrading the firmware. Ir is NO SOLUTION for real defects.
You even can't upgrade if the device is not working correct.
It needs to run a short program, put is a small part of the RAM, and during the upgrade it can't lose power, because the little program has to flash (put new software in) the electrical erasable memory.
When something goes wrong during the update, nothing works and you need to visit a service centre to put things right.
As long as your TV works fine, don't update. When LG really does have an update, they will email all registered owners and carefully explain how to do the upgrade.
To be sure about any updates, register your TV on the support site.
When you have a problem with the TV contact LG or a certified repair centre close to you.
It would not be wise to try to change something on your TV, as long as you are not 100% sure it would improve the TV.
Jan 18, 2015 | LG Televison & Video
Im trying to find a firmware update for my LG 47LG50 47" LCD TV? where and how do i do this?
I've checked the LG support website. The product is discontinued but if you register your product you may get downloads of firmware upgrades, etc. With my phillips I couldn't see any firmware upgrades until I registered my product. Register here!
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=47LG50&matchedModelCode=1000003999&searchEngineModelCode=47LG50&initialTab=documents&targetPage=support-product-profile
Please rate if this helped :)
Mar 10, 2011 | LG 47LG50 47 in. LCD HDTV
I reciebe all the new channels but 7mate and gem have no volume, I have tried everything is there a certain cord or set top box I need.........Please help....
i have had this same problem with many of my customers of late...have not found and hard and fast solution however try retuning the tv or upgrading the firmware. I think you may have to contact LG regarding a firmware upgrade as this tv has no network connections or usb ports. i had to replace a set top box for a newer model for this same reason.
Oct 07, 2010 | LG 42LC2D 42 in. LCD HDTV
32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Feb 23, 2010 | Televison & Video
Jan 17, 2010 | LG 42LC2D 42 in. LCD HDTV
How can i tell if my lg tv has the lip sync firmware fix
In the menue go to Update firmware. It will display the firmware number. reply no when it ask if you want to upgrade. Contact LG any tell them the numbers. They will tell you if firmware upgrade is current or not. They will send you the upgrade if it's needed.
Nov 22, 2009 | LG 55LH40 55 in. LCD HDTV
LG 42LB5D Lcd sound cuts
sounds like you need a firmware upgrade one of the reported fixs on this model for your problem is to do a firmware upgrade. I don't think LG will send the file to a consumer but you need to call them anyway it goes if ti's not firmware then it's most likey the digital cba assy. LG 800-253-0000 Good Luck
Mar 08, 2008 | Televison & Video
Televison & Video Logo
331 people viewed this question
